cgal-discuss - [Fwd: 3D Voronoi diagrams]
  • To:
  • Subject: [Fwd: 3D Voronoi diagrams]
  • Date: Thu, 8 Nov 2007 19:19:41 +0100 (CET)
  • Importance: Normal
---------------------------- Original Message ----------------------------
Subject: 3D Voronoi diagrams
Date: Thu, November 8, 2007 11:58
To:
I am interested in 3D Voronoi diagrams, and in generic presentations of
CGAL there is often the statement that the library includes
routines for 3D Voronoi diagrams. Unfortunately I could not find any
such routine in the manual and there are no examples in the demo and the
examples directory. Still the library computes the 3D Delaunay
triangulation, and there is a function CGAL::surface_neighbors_3 that
may be used to select intersections of the midplanes cutting through the
Delaunay edges. Is this what should be done? Should one start from the
triangulation and then build the Voronoi cells and select edges and
vertices to define the facets of the Voronoi cells?
Thank you.
Best Regards,
Edoardo Milotti
Edoardo Milotti
Address:
Dipartimento di Fisica dell'Università di Trieste
and I.N.F.N. - Sezione di Trieste
Via Valerio, 2
I-34127 Trieste, Italy
e-mail:
phone: +39 040 558 3388
fax: +39 040 558 3350
http://www.ts.infn.it/~milotti/index.html
I am interested in 3D Voronoi diagrams, and in generic presentations of CGAL there is often the statement that the library includes routines for 3D Voronoi diagrams. Unfortunately I could not find any such routine in the manual and there are no examples in the demo and the examples directory. Still the library computes the 3D Delaunay triangulation, and there is a function CGAL::surface_neighbors_3 that may be used to select intersections of the midplanes cutting through the Delaunay edges. Is this what should be done? Should one start from the triangulation and then build the Voronoi cells and select edges and vertices to define the facets of the Voronoi cells?
Thank you.
Best Regards,
Edoardo Milotti
Edoardo Milotti
Address:
Via Valerio, 2
e-mail:
