- To:
- Subject: errors I get from segment_delaunay_graph_2.h
- Date: Sat, 10 Nov 2007 07:53:18 +0100
Hello,
I have a problem using segment_delaunay_graph_2.h.
when I want to compile my project, in the above file I get several errors:
for "typedef typename Geom_traits::Arrangement_type_2 AT2;":
error C2039: 'Arrangement_type_2' : is not a member of 'CGAL::Sdgtw2<Gt_base>'
with
Gt_base=int
for these lines:
typedef typename Storage_traits::Point_container Point_container;
typedef typename Storage_traits::Point_handle Point_handle;
typedef typename Storage_traits::const_Point_handle const_Point_handle;
I get:
error C2039: 'const_Point_handle' & 'Point_handle' & 'Point_container': is
not a member of 'CGAL::Boolean_tag<b>'
with
b=true
and for site_2 and others...
but when I run the demo of segment delaunay, there is no problem. I did not
explicitly set tag to true, but I wonder how this was done.
In reference manual (page 2001), these are defined for "DelaunayGraph 2":
>Types
>typedef Gt Geom traits; A type for the geometric traits.
>typedef DS Data structure; A type for the underlying data structure.
>typedef Data structure Triangulation data structure;
>This type has been added so that the
>Segment Delaunay graph 2<Gt,DS> class
>is a model of the DelaunayGraph 2 concept.
>typedef typename DS::size type size type; Size type (an unsigned integral
>>type)
>typedef typename Gt::Point 2 Point 2; A type for the point defined in the
>>geometric
>traits.
>typedef typename Gt::Site 2 Site 2; A type for the segment Delaunay graph
>site, defined in the geometric traits.
>Segment Delaunay graph 2<Gt,DS>:: Point container A type for the container
>of >points.
>typedef typename Point container::iterator Point handle; A handle for points
>>in the point container.
so who is causing this problem? it is now the third day I am struggling with
this error?
- errors I get from segment_delaunay_graph_2.h, nt_mahmood, 11/10/2007
- Re: [cgal-discuss] errors I get from segment_delaunay_graph_2.h, Camille Wormser, 11/10/2007
