cgal-discuss - Re: [cgal-discuss] errors I get from segment_delaunay_graph_2.h
  • To:
  • Subject: Re: [cgal-discuss] errors I get from segment_delaunay_graph_2.h
  • Date: Sat, 10 Nov 2007 08:12:23 +0100
wrote:
when I want to compile my project, in the above file I get several errors:
for "typedef typename Geom_traits::Arrangement_type_2 AT2;":
error C2039: 'Arrangement_type_2' : is not a member of 'CGAL::Sdgtw2<Gt_base>'
with
Gt_base=int
error C2039: 'const_Point_handle' & 'Point_handle' & 'Point_container': is not a
member of 'CGAL::Boolean_tag<b>'
with
b=true
so who is causing this problem? it is now the third day I am struggling with this error?
It seems that your are not instantiating the Segment_Delaunay_graph templates parameters properly. You should at least provide the relevant lines of code.
