cgal-discuss - Re: [cgal-discuss] errors I get from segment_delaunay_graph_2.h
  • To:
  • Subject: Re: [cgal-discuss] errors I get from segment_delaunay_graph_2.h
  • Date: Fri, 9 Nov 2007 23:45:02 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=gdeCe8KtYphpIwjch+4sRczbvetmpkNdJDt+KasfbdbcdPPMeUeJvR5iosOODIR09UWB7YGVLc/lZ2Us04wZx2Wut3AbqRFC/LP9oh/xYgqZ4n7ketq2SivOiXv5sqCIDj+m6TCfy/qCDqug5lXFTRa4QNj3lQRyfgAuFKVcXdg=;
 Hello and thanks,
what do you mean "not instantiating the Segment_Delaunay_graph templates parameters properly"? can you explain more.
Also the section of segment_delaunay_graph_2.h that has problem is:
template<class Gt,
class ST = Segment_Delaunay_graph_storage_traits_2<Gt>,
class DS = Triangulation_data_structure_2 <
Segment_Delaunay_graph_vertex_base_2<ST>,
Triangulation_face_base_2<Gt> >,
class LTag = Tag_false >
class Segment_Delaunay_graph_2
: private Triangulation_2<
Segment_Delaunay_graph_traits_wrapper_2<Gt>, DS >
friend class Segment_Delaunay_graph_hierarchy_2<Gt,ST,Tag_true,DS,LTag>;
friend class Segment_Delaunay_graph_hierarchy_2<Gt,ST,Tag_false,DS,LTag>;
protected:
// LOCAL TYPES
typedef Segment_Delaunay_graph_2<Gt,ST,DS,LTag> Self;
typedef Segment_Delaunay_graph_traits_wrapper_2<Gt> Modified_traits;
typedef Triangulation_2<Modified_traits,DS> DG;
typedef DG Delaunay_graph;
typedef LTag List_tag;
public:
// PUBLIC TYPES
typedef DS Data_structure;
typedef DS Triangulation_data_structure;
typedef Gt Geom_traits;
typedef ST Storage_traits;
typedef typename Gt::Site_2 Site_2;
typedef typename Gt::Point_2 Point_2;
typedef typename DS::Edge Edge;
typedef typename DS::Vertex_handle Vertex_handle;
typedef typename DS::Face_handle Face_handle;
typedef typename DS::Vertex Vertex;
typedef typename DS::Face Face;
typedef typename DS::size_type size_type;
typedef typename DS::Vertex_circulator Vertex_circulator;
typedef typename DS::Edge_circulator Edge_circulator;
typedef typename DS::Face_circulator Face_circulator;
typedef typename DS::Face_iterator All_faces_iterator;
typedef typename DS::Vertex_iterator All_vertices_iterator;
typedef typename DS::Edge_iterator All_edges_iterator;
typedef typename DG::Finite_faces_iterator Finite_faces_iterator;
typedef typename DG::Finite_vertices_iterator Finite_vertices_iterator;
typedef typename DG::Finite_edges_iterator Finite_edges_iterator;
typedef typename Storage_traits::Point_container Point_container;
typedef typename Storage_traits::Point_handle Point_handle;
typedef typename Storage_traits::const_Point_handle const_Point_handle;
Mahmood NT
----- Original Message ----
To:
Sent: Saturday, November 10, 2007 10:42:23 AM
wrote:
> when I want to compile my project, in the above file I get several errors:
> for "typedef typename Geom_traits::Arrangement_type_2  AT2;":
> error C2039: 'Arrangement_type_2' : is not a member of 'CGAL::Sdgtw2<Gt_base>'
>        with
>            Gt_base=int
> error C2039: 'const_Point_handle' & 'Point_handle' & 'Point_container': is not a member of 'CGAL::Boolean_tag<b>'
>        with
>            b=true
> so who is causing this problem? it is now the third day I am struggling with this error?
It seems that your are not instantiating the Segment_Delaunay_graph
templates parameters properly. You should at least provide the relevant
lines of code.
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
