- To:
- Subject: Re: [cgal-discuss] errors I get from segment_delaunay_graph_2.h
- Date: Sat, 10 Nov 2007 08:53:21 +0100
Mahmood NT wrote:
I mean that the parameters that you give to the Segment_Delaunay_graph class (between "<>") may be wrong.
You should provide your code rather than CGAL code, so that we can see if the problem is there or not. -- Camille Wormser |
- Re: [cgal-discuss] errors I get from segment_delaunay_graph_2.h, Mahmood NT, 11/10/2007
- Re: [cgal-discuss] errors I get from segment_delaunay_graph_2.h, Camille Wormser, 11/10/2007
- <Possible follow-up(s)>
