cgal-discuss - Re: [cgal-discuss] errors I get from segment_delaunay_graph_2.h
  • To:
  • Subject: Re: [cgal-discuss] errors I get from segment_delaunay_graph_2.h
  • Date: Sat, 10 Nov 2007 00:10:58 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=mX9uW43GCBqA+7LpcdVnUFaM8x2/LUP2InJw4/rf2RvqV2tnpRcCLORrC/F6AauhvoFOhz0qNIFE3TSmMBideAW+QkoInIBI6If60RVC4Mh10W6jzAc5ERQWLndEZdWAbo26KsRXj0KGiBEEj1Nn8/FWN11+JEciEROXoPu/hIA=;
I have
typedef  Segment_Delaunay_graph_filtered_traits_without_intersections_2  <Kernel, Ring_tag, Kernel, Ring_tag> Sdg_traits_2;
and I include #include <CGAL/Segment_Delaunay_graph_traits_2.h>. in this header, the file "segment_delaunay_graph_2.h" is included and seems to cause the problem.
first the compile didnot recognize Ring_tag. Alghouth in the manual "CGAL::Ring_tag" is valid but even when I add:
typedef CGAL::Ring_tag Ring_tag;
it says that Ring_tag is not a member of CGAL! did I miss something to include for Ring_tag?
after that I change it to typedef CGAL::Field_with_sqrt_tag Ring_tag; this time the Ring_tag problem solved but still storage_triats problem (or as you mentioned, instantiating problem) is still remaining.
Mahmood NT
----- Original Message ----
To:
Sent: Saturday, November 10, 2007 11:23:21 AM
Mahmood NT wrote:
what do you mean "not instantiating the Segment_Delaunay_graph templates parameters properly"? can you explain more.
I mean that the parameters that you give to the Segment_Delaunay_graph class (between "<>") may be wrong.
Also the section of segment_delaunay_graph_2.h that has problem is:
You should provide your code rather than CGAL code, so that we can see if the problem is there or not.
Camille Wormser
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
