cgal-discuss - Re: [cgal-discuss] compiling problem in linux
  • To:
  • Subject: Re: [cgal-discuss] compiling problem in linux
  • Date: Sat, 17 Nov 2007 17:02:05 +0100
Mahmood NT wrote:
>You should switch to CGAL 3.3.1 or use a gcc compiler available at the time
>when CGAL 3.2 was released. When we release we cannot test with compilers
>which do not yet exist
>What about trying CGAL 3.3 ?
I have a code which is compatible with CGAL 3.2. when I use CGAL 3.3.1, I have some errors and I recently post "errors I get from segment_delaunay_graph_2.h" and although I have some question and answer with Camille Wormser, but it has not solved yet.
It hasn't been solved, as you didn't listen to what Camille wrote
namely to post YOUR code and not sniplets of CGAL code
so I decided to use previous and compatible version of CGAL.
>It might be helpful to write WHERE you type make.
when I am in my project folder (which has a makefile) and try to make. CGAL has been installed successfully.
>Is it really the same, or is it just the same function name.
>Note that there exist millions of programs with a function
>called main() without having much in common. So if my main
>and compiles it might well be that your's doesn't ===:>-
nice tip ;) it was my fault. but what should I do? Thanks,
----- Original Message ----
To:
Sent: Saturday, November 17, 2007 7:00:46 PM
<mailto:>
wrote:
> Hello,
> After some challenge with MS .NET 2003, I decided to compile in linux. the specifications are:
> CGAL 3.2
> OS: i686_Linux-2.6 > Compiler: GNU 3.4.2 > Support for: BOOST, X11, GMP, MPFR, CORE, ZLIB, and QT.
> by using "make" I get some errors in a file, one of them is:
[snip]
> An intresting thing is the same finite_edges_begin() is used in "Alpha" example but with different definition and without compilation error. I mean in "Alpha_shape_3.h" it is:
> > typedef typename Dt::Finite_cells_iterator Finite_cells_iterator;
> Finite_edges_iterator eit = finite_edges_begin();
> for( ; eit != finite_edges_end() ; ++eit){
> if (classify(*eit, alpha) == type) *it++ = *eit;
> what is wrong with finite_edges_begin() or GCC? if installation menu shows that it supports for GCC 3.4, so why it does have problem?
andreas
> Thanks,
Get easy, one-click access to your favorites. Make Yahoo! your homepage. <http://us.rd.yahoo.com/evt=51443/*http://www.yahoo.com/r/hs>
