- To:
- Subject: Re: [cgal-discuss] compiling problem in linux
- Date: Wed, 21 Nov 2007 07:54:15 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=1zhxzC3jtqpL2rb+j9g14sp/LW+af+olUblCrsGT9cMxU7LlG3JxZ2YyS/zMNmvMSXj6dX050WSaqrebrkHgdYnWt/qIWgcHTuRipF0CUqn+uD8ipqGxeu40otIufXL9nwSgJ1qBmCo8/JslygfXpJYVq6QUFBLJ2sSJ+RO/yLg=;
>It hasn't been solved, as you didn't listen to what Camille wrote
>namely to post YOUR code and not sniplets of CGAL code
Hello,
I put the code in http://ce.sharif.edu/~m_naderan
If some one can run it with any CGAL version (especialy 3.3.1) and any OS (linux or windows), I will be very thankfull. It has problem with segment_delaunay instantiation in CGAL 3.3.1.
Thanks,
----- Original Message ----
To:
Sent: Saturday, November 17, 2007 7:32:05 PM
Mahmood NT wrote:
> >You should switch to CGAL 3.3.1 or use a gcc compiler available at the
> time
> >when CGAL 3.2 was released. When we release we cannot test with compilers
> >which do not yet exist
> >What about trying CGAL 3.3 ?
> I have a code which is compatible with CGAL 3.2. when I use CGAL 3.3.1,
> I have some errors and I recently post "errors I get from
> segment_delaunay_graph_2.h" and although I have some question and answer
> with Camille Wormser, but it has not solved yet.
> so I decided to
> use previous and compatible version of CGAL.
> >It might be helpful to write WHERE you type make.
> when I am in my project folder (which has a makefile) and try to make.
> CGAL has been installed successfully.
> >Is it really the same, or is it just the same function name.
> >Note that there exist millions of programs with a function
> >called main() without having much in common. So if my main
> >and compiles it might well be that your's doesn't ===:>-
> nice tip ;) it was my fault. but what should I do?
> Thanks,
> From: Andreas Fabri <>
> To:
> Sent: Saturday, November 17, 2007 7:00:46 PM
> <mailto:> wrote:
> > Hello,
> > After some challenge with MS .NET 2003, I decided to compile in
> linux. the specifications are:
> > CGAL 3.2
> You should switch to CGAL 3.3.1 or use a gcc compiler available at the time
> > OS: i686_Linux-2.6
> > Compiler: GNU 3.4.2
> > Support for: BOOST, X11, GMP, MPFR, CORE, ZLIB, and QT.
> > by using "make" I get some errors in a file, one of them is:
> [snip]
> > An intresting thing is the same finite_edges_begin() is used in
> "Alpha" example but with different definition and without compilation
> error. I mean in "Alpha_shape_3.h" it is:
> > typedef typename Dt::Finite_cells_iterator Finite_cells_iterator;
> > Finite_edges_iterator eit = finite_edges_begin();
> > for( ; eit != finite_edges_end() ; ++eit){
> > if (classify(*eit, alpha) == type) *it++ = *eit;
> > what is wrong with finite_edges_begin() or GCC? if installation menu
> shows that it supports for GCC 3.4, so why it does have problem?
> andreas
> > Thanks,
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> Get easy, one-click access to your favorites. Make Yahoo! your homepage.
> <http://us.rd.yahoo.com/evt=51443/*http://www.yahoo.com/r/hs>
To:
> time
> so I decided to
> Thanks,
> To:
> <mailto:> wrote:
> > Hello,
> > CGAL 3.2
> > OS: i686_Linux-2.6
> > Compiler: GNU 3.4.2
> [snip]
> andreas
> > Thanks,
Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how.
- Re: [cgal-discuss] compiling problem in linux, Mahmood NT, 11/17/2007
- Re: [cgal-discuss] compiling problem in linux, Andreas Fabri, 11/17/2007
- <Possible follow-up(s)>
- Re: [cgal-discuss] compiling problem in linux, Mahmood NT, 11/21/2007
