- To:
- Subject: Is it a bug of Polyhedron_3? (integration with boost graph)
- Date: Sat, 17 Nov 2007 09:34:31 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=HpWH4wPWtVuXcknPfw3YeSF9Wug9xwbdYqPSNB5h9pT/9L/AtxDXCN1A6s0T3A0SzyLUobPlNHZ76c1UssthTXbo54vrX6moRswRAZEuk/r8KJ7AFKOWnpiYmDCd8ICsQShzokwdI+fK1wHGmDQWw3cFKk+3kUF+TsXEU6Ju+0k=;
Dear CGAL users,
I have a problem of integration of boost graph (BGL) and CGAL::Polyhedron_3. If I use dijkstra algorithm with Polyhedron_3, it will report some errors. I simplified the code and write a toy project. Can you point out the problem?
Is it a bug of CGAL?
Here is the code, and I compiled it on WinXP64 + Visual Studio 2005 sp1:
#include <CGAL/Cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/Polyhedron_items_with_id_3.h>
#include <CGAL/boost/graph/graph_traits_Polyhedron_3.h>
#include <CGAL/boost/graph/properties_Polyhedron_3.h>
typedef CGAL::Cartesian<double> Kernel;
typedef Kernel::Point_3 Point;
typedef CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3> Polyhedron;
typedef boost::graph_traits<Polyhedron>::vertex_descriptor vertex_descriptor;
typedef boost::graph_traits<Polyhedron>::vertex_iterator vertex_iterator;
template <typename VertexListGraph>
void test(const VertexListGraph& g)
typename boost::graph_traits<VertexListGraph>::vertex_iterator ui, ui_end;
boost::tie(ui, ui_end) = boost::vertices(g);
int main() {
Polyhedron P;
Point a(1,0,0);
Point b(0,1,0);
Point c(0,0,1);
Point d(0,0,0);
P.make_tetrahedron(a,b,c,d);
test(P);
return 0;
And here is the output of my compiler:
1>------ Build started: Project: cons, Configuration: Release Win32 ------
1>Compiling...
1>cons.cpp
1>D:\Lib\boost\boost/tuple/detail/tuple_basic.hpp(637) : error C2679: binary '=' : no operator found which takes a right-hand operand of type 'const CGAL::HDS_all_vertices_const_iterator<HDS>' (or there is no acceptable conversion)
1> with
1> [
1> HDS=CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3>
1> ]
1> D:\Lib\CGAL-3.3.1\include\CGAL/boost/graph/graph_traits_HalfedgeDS.h(158): could be 'CGAL::HDS_all_vertices_iterator<HDS> &CGAL::HDS_all_vertices_iterator<HDS>::operator =(const CGAL::HDS_all_vertices_iterator<HDS> &)'
1> with
1> [
1> ]
1> while trying to match the argument list '(CGAL::HDS_all_vertices_iterator<HDS>, const CGAL::HDS_all_vertices_const_iterator<HDS>)'
1> with
1> [
1> ]
1> .\cons.cpp(20) : see reference to function template instantiation 'boost::tuples::tuple<T0,T1,T2,T3,T4,T5,T6,T7,T8,T9> &boost::tuples::tuple<T0,T1,T2,T3,T4,T5,T6,T7,T8,T9>::operator =<CGAL::HDS_all_vertices_const_iterator<HDS>,CGAL::HDS_all_vertices_const_iterator<HDS>>(const std::pair<_Ty1,_Ty2> &)' being compiled
1> with
1> [
1> T0=CGAL::HDS_all_vertices_iterator<CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3>> &,
1> T1=CGAL::HDS_all_vertices_iterator<CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3>> &,
1> T2=boost::tuples::null_type,
1> T3=boost::tuples::null_type,
1> T4=boost::tuples::null_type,
1> T5=boost::tuples::null_type,
1> T6=boost::tuples::null_type,
1> T7=boost::tuples::null_type,
1> T8=boost::tuples::null_type,
1> T9=boost::tuples::null_type,
1> HDS=CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3>,
1> _Ty1=CGAL::HDS_all_vertices_const_iterator<CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3>>,
1> _Ty2=CGAL::HDS_all_vertices_const_iterator<CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3>>
1> ]
1> .\cons.cpp(35) : see reference to function template instantiation 'void test<Polyhedron>(const VertexListGraph &)' being compiled
1> with
1> [
1> VertexListGraph=Polyhedron
1> ]
1>D:\Lib\boost\boost/tuple/detail/tuple_basic.hpp(638) : error C2679: binary '=' : no operator found which takes a right-hand operand of type 'const CGAL::HDS_all_vertices_const_iterator<HDS>' (or there is no acceptable conversion)
1> with
1> [
1> ]
1> with
1> [
1> ]
1> with
1> [
1> ]
1>Build Time 0:04
1>Build log was saved at "file://d:\misc\cons\Release\BuildLog.htm"
1>cons - 2 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Thanks a lot
int main() {
Polyhedron P;
Point a(1,0,0);
Point b(0,1,0);
Point c(0,0,1);
Point d(0,0,0);
test(P);
return 0;
1>Compiling...
1>cons.cpp
1> with
1> [
1> ]
1> with
1> [
1> ]
1> with
1> [
1> ]
1> with
1> [
1> ]
1> with
1> [
1> ]
1> with
1> [
1> ]
1> with
1> [
1> ]
1> with
1> [
1> ]
1>Build Time 0:04
Thanks a lot
Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how.
- Is it a bug of Polyhedron_3? (integration with boost graph), Tux Han, 11/17/2007
