- To:
- Subject: Re: [cgal-discuss] A compiler Error
- Date: Tue, 20 Nov 2007 17:58:28 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:mime-version:content-type; b=Iapum6tGjfSUom5oRLOrS5Nb7QgjiCtgVx7tCCCq6bHCYaEKR+ZsQ7y1h+4ijfsPhyAOzWrZ+pf4fhq5uub46Y8ocTsfc2H+qmKB2QRp/hH8QJYrw8aZz7lKFnIAiq33memk7p8jWPUZwTj44jl2fZMkWv6cl+MO7qfOzTwajwo=
Hi Again,
I have downloaded the Visual Studio 2005 Professional Edition SP1 and installed it. Then I tried the examples of CGAL and know the examples ,including the straight_ skeleton2 example, are working without giving an error. Beside this I am continuing to take the same warnings, but it seems there is no problem.
Thanks for your help.
Sinan MUTLU
sinan mutlu wrote:
Hi again,The contents of your target folder are OK, and the manifest is OK too, so I'm lost since I can't reproduce your problems here.
I am using the Professional Edition of Visual Studio 2005. An I have done
all the things that are listed as below.
I attached the files which you required from me.
I can build the Straight_skeleton_2 example with no linker warning at all, and I can run the application without any problems.
If I can think of something I let you know.
Fernando Cacciola
GeometryFactory
- Re: [cgal-discuss] A compiler Error, Mahmood NT, 11/20/2007
- <Possible follow-up(s)>
- Re: [cgal-discuss] A compiler Error, sinan mutlu, 11/20/2007
