- To:
- Subject: Re: [cgal-discuss] A compiler Error
- Date: Mon, 19 Nov 2007 23:19:31 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=uGBgKtSh/f9ncAtkknvc0RC+2QwPOMZAzA5XPbUCLPAtdaFqh88rbv3wg3keYfOHUSVQW6I/BfmxDFp/PC3Q92fo3KDqugJ2dtJVjwMr8/OlHtixeyb76Ux56JPfYmWhnM//TTeqHMzphkag0iYK9uARBh8doRl47509vJeu7Dc=;
Hi,
I have the same problem for some examples. Although they are warnning, but the project can not be run in VC8.0.
Use VC7.0 if you want to run it.
Mahmood NT
----- Original Message ----
To:
Sent: Monday, November 19, 2007 7:52:46 PM
Subject: [cgal-discuss] A compiler Error
Hi,
I am trying to compile & run the "straight_skeleton_2" example. It compiles successfully but while compiling it it gives 83 warnings like:
Warning 1 warning LNK4099: PDB 'vc80.pdb' was not found with 'D:\Program Files\CGAL- 3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'd:\Program Files\CGAL-3.3.1\examples\Straight_skeleton_2\VC\Debug\vc80.pdb'; linking object as if no debug info gmp-vc80-mt-gd.lib
Then while trying to run it, Visual Studio 8.0 gives an error like this:
"Unable to start program 'D:\Program Files\CGAL-3.3.1\examples\Straight_skeleton_2\Straight_skeleton_2.exe'.
This application has failed to start because of the application configuration is incorrect. Review the manifest of possible errors. Reinstalling the application may fix the problem..."
I am a new user of the CGAL - 3.3.1. I reinstalled it but again I got the same errors. I thing the error comes form the file "...\CGAL-3.3.1\include\CGAL\CORE\poly\Poly.tcc" file.
Then I commented the lines:
if( x < 0 && k%2 != 0) {
return Type(-CORE::radical( -x, k ) );
return Type( CORE::radical( x, k ) );
of the file "...\CGAL- 3.3.1\include\CGAL\CORE_BigFloat.h" it gives no error. I think the problem comes from here. Maybe there is a basic problem that I am missing.
Can someone please help me!?
Thank you...
Sinan MUTLU
To:
Hi,
Thank you...
Sinan MUTLU
Never miss a thing. Make Yahoo your homepage.
- Re: [cgal-discuss] A compiler Error, Mahmood NT, 11/20/2007
- <Possible follow-up(s)>
- Re: [cgal-discuss] A compiler Error, sinan mutlu, 11/20/2007
