- To: <>
- Subject: Re: [cgal-discuss] Straight Skeleton original code
- Date: Thu, 22 Nov 2007 13:08:13 -0300
- Organization: Geometry Factory
Hi Xiangzhi,
Hi Fernando Cacciola !Did you applied the patch I posted and re-build the demo program?
Thanks very much for your help!
Two degeneration cases are listed in the attachment. if there are at least
two becoming edges collinear during the shrinking process. As a result, the
shape of straight skeleton seems incorrect !!
Can you post the polygon that produces the first example (the one that is missing the "vertex" event)?
Best
Fernando Cacciola
GeometryFactory
- Re: [cgal-discuss] Straight Skeleton original code, (continued)
- Re: [cgal-discuss] Straight Skeleton original code, Fernando Cacciola, 11/22/2007
- Re: [cgal-discuss] Straight Skeleton original code, xiangzhi wei, 11/22/2007
- RE: [cgal-discuss] Straight Skeleton original code, Amir Vaxman, 11/22/2007
- Re: [cgal-discuss] Straight Skeleton original code, xiangzhi wei, 11/23/2007
- Re: [cgal-discuss] Straight Skeleton original code, Fernando Cacciola, 11/23/2007
- Re: [cgal-discuss] Straight Skeleton original code, sinan mutlu, 11/23/2007
- Re: [cgal-discuss] Straight Skeleton original code, xiangzhi wei, 11/24/2007
