- To: <>
- Subject: Re: [cgal-discuss] Straight Skeleton original code
- Date: Thu, 22 Nov 2007 13:33:42 -0300
- Organization: Geometry Factory
Hello Amir,
The case you discuss is not a "split event" , it is what Eppstein & EricksonIndeed.
called a "vertex event" in his article:
And the package handles it correctly (though its call "pseudo split" event).
The manual references precisely that article as the additional algorithm
source.
Best
Fernando
- Re: [cgal-discuss] Straight Skeleton original code, (continued)
- Re: [cgal-discuss] Straight Skeleton original code, xiangzhi wei, 11/22/2007
- Re: [cgal-discuss] Straight Skeleton original code, Fernando Cacciola, 11/22/2007
- RE: [cgal-discuss] Straight Skeleton original code, Amir Vaxman, 11/22/2007
- Re: [cgal-discuss] Straight Skeleton original code, xiangzhi wei, 11/23/2007
- Re: [cgal-discuss] Straight Skeleton original code, Fernando Cacciola, 11/23/2007
- Re: [cgal-discuss] Straight Skeleton original code, sinan mutlu, 11/23/2007
- Re: [cgal-discuss] Straight Skeleton original code, xiangzhi wei, 11/24/2007
