cgal-discuss - Minimum number of straight line segments between two points at the ends of a planar sequence of triangles
  • To:
  • Subject: Minimum number of straight line segments between two points at the ends of a planar sequence of triangles
  • Date: Mon, 26 Nov 2007 22:24:20 +0000
Hi -
I'm trying to solve the following problem (actually, I need the solution for my work), and I'm not sure if its been solved Any information, pointers or solutions will be appreciated.
Given: sequence of n coplanar triangles, T[1] ... T[n], such that each interior triangle T[i] shares and edge with its neighbors T[i-1] and T[i+1]. The triangles T[0] and T[n] have only one neighbor each (T[1] and T[n-1] respectively), and contain a start and and end point A and B respectively, as illustrated in the following diagram: http://i17.photobucket.com/albums/b52/videohead/Triangle_Path.jpg
Note that the sequence of triangles consists of (n - 1) shared edges.
I'd like to draw a sequence of straight line paths (hitherto called L's) between A and B such that:
1. the number of L's is minimum. In the simplest case, there is only one straight line path L[1] between A and B.
2. consecutive straight line paths meet end-on-end, and may or may not terminate at a shared edge.
3. each straight line path L[j] intersects a subset of the (n-1) shared edges of the triangle sequence,
4. as a result of condition 2 and 3, consecutive L's must touch but must *not* intersect each other.
I think it can be recast as a problem of how many men (lets assume they are hearing-impared, and they can see unocculuded objects at any distance) to place in a winded tunnel so that each man can observe pass a visual signal from the man before him to the next. Its a bit like the art-gallery problem only that the men only have to observe the next man in the winded tunnel.
Thanks,
- Olumide
  • Minimum number of straight line segments between two points at the ends of a planar sequence of triangles, Olumide, 11/26/2007
