cgal-discuss - Re: [cgal-discuss] Intersection between 3D segments / rays and a triangle surface mesh
  • To:
  • Subject: Re: [cgal-discuss] Intersection between 3D segments / rays and a triangle surface mesh
  • Date: Mon, 26 Nov 2007 21:25:25 -0600
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=IBP7gL2qfifOgpHANMpcwBKy0LfGQCEjy5rjXtRcLf40e6y4cH+V6MeNBmTl3ziiDV0p2zA5KCCNqYZ6RRrHf1bzNKuXHp5Es+KDaJHndZdbeMuPInuVfm8TOfMlfANhskzd04IIwOJJIzMT/TEG7lC39Cy9MCUI04dVWsss1gA=
Open Dynamics Engine recently switched from OPCODE to GIMPACT which
apparently can handle concave collisions.
wes
On Nov 26, 2007 4:09 PM, Pierre Alliez
wrote:
> hi all,
> I am sure that this question has already been discussed, but I would like to
> know if some of you had some experience recently about this issue:
> I want to compute efficiently a 3D segment or ray with a (possibly large)
> surface triangle mesh.
> We already have an octree-based implementation, but it is not fully
> satisfactory. I was advised to take a look at the OPCODE library (collision
> detection) and could see many others as well: ColDet, SOLID, RAPID, Swift++
> PQP, etc.
> Before digging more into these libs, did you already solve the same problem
> in
> for your applications? which lib do you recommend? any help would be much
> appreciate.
> best regards,
> pierre
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
