- To:
- Subject: Re: [cgal-discuss] reducing compile time
- Date: Tue, 27 Nov 2007 01:52:58 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=YYpMBDdOya+kky0VxjCJ50KGtWsIGM8ibAoYw5mlxRi5x+4nVqicWKdOgOPj3mpflF3r817y28IJFDoJ8NkeYt7MSK/afDMDHxXM/0X0nVOSTYX5sDX1ySLn0Zr822donIDUV+uo72GSyn30hzpd/GoJtWloweXDLDSMS+9lsSc=;
>It depends on the compiler, but for example with g++ you can use
>precompiled headers. In such a header, you can put as much stuff
>as you wish, especially template instantiations as Fernando mentioned,
>but already including many files can help. Then you precompile it,
>and the compiler loads the precompiled versions automatically
>if you specify something like "-include my_pch.h" on the command line.
>It has the benefit that you do not need to re-organize your source
>files (like concatenating all your *.cpp files before compiling them
>in one go instead of doing several compilations for each of them).
I have the same problem with compilation time with gcc.
Can you explain more about how to create and use precompiled header. any link, webpage,...
what should I do with makefile?
----- Original Message ----
To:
Sent: Thursday, November 22, 2007 10:23:32 PM
Gabriel Cirio a écrit :
> Hello,
> is there any tip or trick to reduce the compile time of a CGAL
> application? I am using an enriched polyhedron template with a bunch of
> templated (since they use the enriched polyhedron) functionalities, and
> it often takes several minutes to compile since every single
> header/template is recompiled each time. Is there a technique to
> minimize template recompilation?
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
To:
> Hello,
Sylvain Pion
Get easy, one-click access to your favorites. Make Yahoo! your homepage.
- Re: [cgal-discuss] reducing compile time, Mahmood NT, 11/27/2007
- Re: [cgal-discuss] reducing compile time, Andreas Fabri, 11/27/2007
- <Possible follow-up(s)>
- Re: [cgal-discuss] reducing compile time, Andreas Meyer, 11/27/2007
