cgal-discuss - Re: [cgal-discuss] reducing compile time
  • To:
  • Subject: Re: [cgal-discuss] reducing compile time
  • Date: Tue, 27 Nov 2007 11:04:49 +0100
Mahmood NT wrote:
>It depends on the compiler, but for example with g++ you can use
>precompiled headers. In such a header, you can put as much stuff
>as you wish, especially template instantiations as Fernando mentioned,
>but already including many files can help. Then you precompile it,
>and the compiler loads the precompiled versions automatically
>if you specify something like "-include my_pch.h" on the command line.
>It has the benefit that you do not need to re-organize your source
>files (like concatenating all your *.cpp files before compiling them
>in one go instead of doing several compilations for each of them).
I have the same problem with compilation time with gcc.
Can you explain more about how to create and use precompiled header. any link, webpage,...
what should I do with makefile?
What about google g++ precompiled header
----- Original Message ----
To:
Sent: Thursday, November 22, 2007 10:23:32 PM
Gabriel Cirio a écrit :
> Hello,
> is there any tip or trick to reduce the compile time of a CGAL
> application? I am using an enriched polyhedron template with a bunch of
> templated (since they use the enriched polyhedron) functionalities, and
> it often takes several minutes to compile since every single
> header/template is recompiled each time. Is there a technique to
> minimize template recompilation?
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
Get easy, one-click access to your favorites. Make Yahoo! your homepage. <http://us.rd.yahoo.com/evt=51443/*http://www.yahoo.com/r/hs>
