- To:
- Subject: Re: [cgal-discuss] reducing compile time
- Date: Tue, 27 Nov 2007 02:21:51 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=Z6EaQb5xQ5hl6GYZ96UuaqYE9VjkgEQ/Sbx49IYCSgi4/FUnwEMcrWgwm9HDPBN+6u7pxK8Dhyugmigdfunfy1vc08jwM7EXYjuqnPEARemB+b0UVe05Z3azcYQyE1P4gM+9hSXleFEtRIKHdpS13kysWMpWZh0q7/rlPBGe/2s=;
>What about google g++ precompiled header
I found some tools: "distcc" and "ccache". But I have to work with them. No comment....
Mahmood NT
----- Original Message ----
To:
Sent: Tuesday, November 27, 2007 1:34:49 PM
Mahmood NT wrote:
> >It depends on the compiler, but for example with g++ you can use
> >precompiled headers. In such a header, you can put as much stuff
> >as you wish, especially template instantiations as Fernando mentioned,
> >but already including many files can help. Then you precompile it,
> >and the compiler loads the precompiled versions automatically
> >if you specify something like "-include my_pch.h" on the command line.
> >It has the benefit that you do not need to re-organize your source
> >files (like concatenating all your *.cpp files before compiling them
> >in one go instead of doing several compilations for each of them).
> I have the same problem with compilation time with gcc.
> Can you explain more about how to create and use precompiled header. any
> link, webpage,...
> what should I do with makefile?
> From: Sylvain Pion <>
> To:
> Sent: Thursday, November 22, 2007 10:23:32 PM
> Gabriel Cirio a écrit :
> > Hello,
> > is there any tip or trick to reduce the compile time of a CGAL
> > application? I am using an enriched polyhedron template with a bunch of
> > templated (since they use the enriched polyhedron) functionalities, and
> > it often takes several minutes to compile since every single
> > header/template is recompiled each time. Is there a technique to
> > minimize template recompilation?
> Sylvain Pion
> INRIA Sophia-Antipolis
> Geometrica Project-Team
> CGAL, http://cgal.org/
> Get easy, one-click access to your favorites. Make Yahoo! your homepage.
> <http://us.rd.yahoo.com/evt=51443/*http://www.yahoo.com/r/hs>
To:
> link, webpage,...
> To:
> > Hello,
> Sylvain Pion
Never miss a thing. Make Yahoo your homepage.
- Re: [cgal-discuss] reducing compile time, Mahmood NT, 11/27/2007
- Re: [cgal-discuss] reducing compile time, Andreas Fabri, 11/27/2007
- <Possible follow-up(s)>
- Re: [cgal-discuss] reducing compile time, Andreas Meyer, 11/27/2007
