- To:
- Subject: Re: [cgal-discuss] Terrain + hierarchy
- Date: Mon, 3 Dec 2007 10:50:05 +0100
Hi,
Thanks for the hint.
On Monday 03 December 2007 10:33,
wrote:
> what if you write
> typedef CGAL::Triangulation_face_base_2<Et> Fb;
> instead of using K as template parameter there?
Face? That I haven't tried, since I thought it was the vertices which had to
contain the z info. Anyway, I get the same errors I did before:
.../CGAL-3.3.1/include/CGAL/Triangulation_hierarchy_2.h:471: error: no type
named ‘Compare_distance_2’ in ‘class Et’
It seems the "Et" does not provide a valid geometrical kernel for the
hierarchycal triangulation (even if it does for the regular trinagulation).
Best,
Daniel
Daniel Duque
http://rincon.uam.es/dir?cw=950067138671875
- Terrain + hierarchy, Daniel Duque Campayo, 12/03/2007
- Re: [cgal-discuss] Terrain + hierarchy, Monique . Teillaud, 12/03/2007
- Re: [cgal-discuss] Terrain + hierarchy, Daniel Duque Campayo, 12/03/2007
- Re: [cgal-discuss] Terrain + hierarchy, Andreas Fabri, 12/03/2007
