- To:
- Subject: Re: [cgal-discuss] Terrain + hierarchy
- Date: Mon, 03 Dec 2007 11:14:25 +0100
Daniel Duque Campayo wrote:
Hello again,
On Monday 03 December 2007 10:51, Andreas Fabri wrote:
Please give the Projection_traits_xy_3 a try. It should fix the problem,
and also works with constrained triangulations, as it provides the
intersection functor.
Yes, this one seems to work fine! Thanks a lot. So, is this class is going to be included in the new releases?
The functionality will move into Trinagulation_euclidean_traits_xy_2 class
The other name is just temporary, to help you out.
andreas
For the record, I include the new code.
Best,
Daniel
#include "Projection_traits_xy_3.h"
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Triangulation_hierarchy_2.h>
#include <CGAL/intersections.h>
#include<vector>
#include<iostream>
#include<string>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Projection_traits_xy_3<K> Et;
typedef CGAL::Triangulation_vertex_base_2<Et> Vbb;
typedef CGAL::Triangulation_hierarchy_vertex_base_2<Vbb> Vb;
typedef CGAL::Triangulation_face_base_2<Et> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<Et,Tds> Dt;
typedef CGAL::Triangulation_hierarchy_2<Dt> Triangulation;
- Terrain + hierarchy, Daniel Duque Campayo, 12/03/2007
- Re: [cgal-discuss] Terrain + hierarchy, Monique . Teillaud, 12/03/2007
- Re: [cgal-discuss] Terrain + hierarchy, Daniel Duque Campayo, 12/03/2007
- Re: [cgal-discuss] Terrain + hierarchy, Andreas Fabri, 12/03/2007
