cgal-discuss - Re: [cgal-discuss] Terrain + hierarchy
  • To:
  • Subject: Re: [cgal-discuss] Terrain + hierarchy
  • Date: Mon, 03 Dec 2007 10:51:22 +0100
Daniel Duque Campayo wrote:
Hi,
Thanks for the hint.
On Monday 03 December 2007 10:33,
wrote:
what if you write
typedef CGAL::Triangulation_face_base_2<Et> Fb;
instead of using K as template parameter there?
Face? That I haven't tried, since I thought it was the vertices which had to contain the z info. Anyway, I get the same errors I did before:
.../CGAL-3.3.1/include/CGAL/Triangulation_hierarchy_2.h:471: error: no type named ‘Compare_distance_2’ in ‘class Et’
It seems the "Et" does not provide a valid geometrical kernel for the hierarchycal triangulation (even if it does for the regular trinagulation).
Best,
Daniel
Hi Daniel,
Please give the Projection_traits_xy_3 a try. It should fix the problem,
and also works with constrained triangulations, as it provides the
intersection
functor.
andreas
// Copyright (c) 1997 INRIA Sophia-Antipolis (France).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL:
svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.3-branch/Triangulation_2/include/CGAL/Triangulation_2.h
// $Id: Triangulation_2.h 37832 2007-04-02 20:40:18Z spion $
// Author(s) : Andreas Fabri, Mariette Yvinec
#ifndef CGAL_PROJECTION_TRAITS_XY_3_H
#define CGAL_PROJECTION_TRAITS_XY_3_H
#include <CGAL/intersection_2.h>
CGAL_BEGIN_NAMESPACE
namespace Projection_traits {
template <class R>
class Orientation_xy_3
public:
typedef typename R::Point_3 Point;
typename R::FT x(const Point &p) const { return p.x(); }
typename R::FT y(const Point &p) const { return p.y(); }
typedef typename R::Point_2 PP;
CGAL::Orientation operator()(const Point& p,
const Point& q,
const Point& r)
typename R::Orientation_2 orient = R().orientation_2_object();
#ifdef CGAL_3_2
return orient(p,q,r);
#else
typename R::Construct_point_2 construct_point_2 =
R().construct_point_2_object();
typename R::Point_2 pp = construct_point_2(x(p), y(p));
typename R::Point_2 qq = construct_point_2(x(q), y(q));
typename R::Point_2 rr = construct_point_2(x(r), y(r));
return orient(pp, qq, rr);
#endif
template <class R>
class Intersect_xy_3
public:
typedef typename R::Point_3 Point_3;
typedef typename R::Segment_3 Segment_3;
typedef typename R::Point_2 Point_2;
typedef typename R::Vector_2 Vector_2;
typedef typename R::Segment_2 Segment_2;
typename R::FT x(const Point_3 &p) const { return p.x(); }
typename R::FT y(const Point_3 &p) const { return p.y(); }
Point_2 project(const Point_3& p)
return Point_2(x(p),y(p));
Object operator()(const Segment_3& s1, const Segment_3& s2)
Point_2 s1p = project(s1.source());
Point_2 t1p = project(s1.target());
Segment_2 s1_2(s1p, t1p);
Segment_2 s2_2(project(s2.source()), project(s2.target()));
Object o = intersection(s1_2,s2_2);
Point_2 pi;
if(assign(pi,o)){
double l1 = std::sqrt(to_double(squared_distance(s1p,t1p)));
double l2 = std::sqrt(to_double(squared_distance(s1p,pi)));
double ratio = l2/l1;
Point_3 p = s1.source() + ratio * (s1.target() - s1.source());
Point_3 res(pi.x(), pi.y(), p.z());
return make_object(res);
} else {
std::cerr << "NOT YET IMPLEMENTED: Intersection is not a point" <<
std::endl;
Point_3 res;
template <class R>
class Compare_distance_xy_3
public:
typedef typename R::FT RT;
Comparison_result operator()(const Point_3& p,const Point_3& q,const
Point_3& r)
Point_2 p2 = project(p);
Point_2 q2 = project(q);
Point_2 r2 = project(r);
return compare_distance_to_point(p2,q2,r2);
template <class R>
class Squared_distance_xy_3
public:
typedef typename R::Line_3 Line_3;
typedef typename R::Line_2 Line_2;
RT operator()(const Line_3& l, const Point_3& p)
Line_2 l2 = Line_2(project(l.point(0)), project(l.point(1)));
return squared_distance(p2, l2);
template <class R>
class Side_of_oriented_circle_xy_3
public:
CGAL::Oriented_side operator() (const Point &p,
const Point &q,
const Point &r,
const Point &s)
typename R::Side_of_oriented_circle_2 side_of_oriented_circle_2 =
R().side_of_oriented_circle_2_object();
#ifdef CGAL_3_2
return side_of_oriented_circle_2(p,
q,
r,
s);
#else
typename R::Point_2 pp(x(p), y(p)), qq(x(q), y(q)), rr(x(r), y(r)),
ss(x(s), y(s));
return side_of_oriented_circle_2(pp,
qq,
rr,
ss);
#endif
} // namespace Projection_traits
template < class R >
class Projection_traits_xy_3 {
public:
typedef Projection_traits_xy_3<R> Traits;
typedef R Rp;
typedef typename Rp::FT FT;
typedef typename Rp::Point_3 Point_2;
typedef typename Rp::Segment_3 Segment_2;
typedef typename Rp::Triangle_3 Triangle_2;
typedef typename Rp::Line_3 Line_2;
typedef typename Rp::Less_x_3 Less_x_2;
typedef typename Rp::Less_y_3 Less_y_2;
typedef typename Rp::Compare_x_3 Compare_x_2;
typedef typename Rp::Compare_y_3 Compare_y_2;
typedef Projection_traits::Orientation_xy_3<Rp> Orientation_2;
//typedef typename Rp::Orientation_2 Orientation_2;
typedef Projection_traits::Side_of_oriented_circle_xy_3<Rp>
Side_of_oriented_circle_2;
//typedef typename Rp::Side_of_oriented_circle_2 Side_of_oriented_circle_2;
typedef Projection_traits::Squared_distance_xy_3<Rp>
Compute_squared_distance_2;
typedef Projection_traits::Compare_distance_xy_3<Rp>
Compare_distance_2;
typedef typename Rp::Construct_segment_3 Construct_segment_2;
typedef typename Rp::Construct_line_3 Construct_line_2;
typedef typename Rp::Construct_triangle_3 Construct_triangle_2;
typedef Projection_traits::Intersect_xy_3<Rp> Intersect_2;
Projection_traits_xy_3()
Projection_traits_xy_3(const Projection_traits_xy_3&)
Projection_traits_xy_3 &
operator=(const Projection_traits_xy_3&)
return *this;
typename Rp::FT
x(const Point_2 &p) const
return p.x();
typename Rp::FT
y(const Point_2 &p) const
return p.y();
Less_x_2
less_x_2_object() const
{ return Less_x_2();}
Less_y_2
less_y_2_object() const
{ return Less_y_2();}
Compare_x_2
compare_x_2_object() const
{ return Compare_x_2();}
Compare_y_2
compare_y_2_object() const
{ return Compare_y_2();}
Compare_distance_2
compare_distance_2_object() const
return Compare_distance_2();
Orientation_2
orientation_2_object() const
{ return Orientation_2();}
side_of_oriented_circle_2_object() const
{return Side_of_oriented_circle_2();}
Intersect_2
intersect_2_object () const
return Intersect_2();
compute_squared_distance_2_object () const
return Compute_squared_distance_2();
Construct_segment_2 construct_segment_2_object() const
{return Construct_segment_2();}
Construct_line_2 construct_line_2_object() const
{return Construct_line_2();}
Construct_triangle_2 construct_triangle_2_object() const
{return Construct_triangle_2();}
CGAL_END_NAMESPACE
#endif // CGAL_PROJECTION_TRAITS_XY_3_H
