cgal-discuss - Re: [cgal-discuss] parameterization of genus-3 mesh
  • To:
  • Subject: Re: [cgal-discuss] parameterization of genus-3 mesh
  • Date: Wed, 05 Dec 2007 10:28:58 +0100
  • Organization: INRIA
Dear Defeng,
To complete my previous email:
Your out.off mesh is fine, except that its genus is 3.
CGAL parameterization package comes with a simple cutting algorithm which is
enough for this mesh.
You may run it e.g. via the "polyhedron_ex_parameterization" example:
> ./polyhedron_ex_parameterization out.off mesh.eps
See the output mesh.eps attached to this email.
Note: "polyhedron_ex_parameterization" has various options to test all features of the parameterization package and write the result as OBJ or EPS files.
Try "./polyhedron_ex_parameterization -h" for usage.
Best regards,
Laurent Saboret
Laurent Saboret wrote:
Dear Defeng,
The error message "FATAL ERROR: Input mesh is not a surface" is printed when parameterize() fails with the error code ERROR_NO_SURFACE_MESH. This specific error code is sent when the input mesh does not enforce: genus = 0, one connected component and at least one border.
The general requirements are given in the documentation:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesh_parameterization/Chapter_main.html#Section_39.1
The package is restricted to "triangulated surfaces which are homeomorphic to a disk", i.e. triangulated meshes, 2-manifold, genus = 0, one connected component and at least one border.
Best regards,
Laurent Saboret
Defeng WANG wrote:
Hi, Laurent,
Thanks for you reply.
I have another question about the sample code "Mesh_cutting_parameterization". When I put in my mesh, I was told that "FATAL ERROR: Input mesh is not a surface". For the convenience to find the problem, I attached the mesh I used. What is the requirent for the input mesh? How to adjust my mesh to be acceptable for the sample code?
Many thanks!
Defeng
----- Original Message ----- From: "Laurent Saboret" <>
To:
Sent: Monday, December 03, 2007 9:47 PM
Hi Defeng,
CGAL Surface_mesh_parameterization package
can parameterize genus-1 meshes (topological disks).
This package does not provide any algorithm to transform an arbitrary mesh into a topological disk, the user being responsible for generating such a cut graph. Nevertheless, we provide a simple cutting algorithm for the sake of completeness. See details at http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesh_parameterization/Chapter_main.html#Section_39.5
Best regards,
Laurent Saboret
INRIA Sophia-Antipolis
Defeng WANG a écrit :
Hello, CGALers,
Ask one quick question, if I want to parameterize of a genus-3 mesh, what should I do by using CGAL?
Thanks for any comments.
Best wishes,
Defeng
image/eps
