- To: <>
- Subject: Re: [cgal-discuss] parameterization of genus-3 mesh
- Date: Thu, 6 Dec 2007 10:45:39 +0800
Dear laurent,
Thank you so much for the detail reply!
Cheers!
Defeng
----- Original Message ----- From: "Laurent Saboret" <>
To:
Sent: Wednesday, December 05, 2007 5:28 PM
Dear Defeng,
To complete my previous email:
Your out.off mesh is fine, except that its genus is 3.
CGAL parameterization package comes with a simple cutting algorithm which is enough for this mesh.
You may run it e.g. via the "polyhedron_ex_parameterization" example:
> ./polyhedron_ex_parameterization out.off mesh.eps
See the output mesh.eps attached to this email.
Note: "polyhedron_ex_parameterization" has various options to test all features of the
parameterization package and write the result as OBJ or EPS files.
Try "./polyhedron_ex_parameterization -h" for usage.
Best regards,
Laurent Saboret
Laurent Saboret wrote:
Dear Defeng,--
The error message "FATAL ERROR: Input mesh is not a surface" is printed
when parameterize() fails with the error code ERROR_NO_SURFACE_MESH.
This specific error code is sent when the input mesh does not enforce:
genus = 0, one connected component and at least one border.
The general requirements are given in the documentation:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesh_parameterization/Chapter_main.html#Section_39.1
The package is restricted to "triangulated surfaces which are
homeomorphic to a disk", i.e. triangulated meshes, 2-manifold, genus =
Best regards,
Laurent Saboret
Defeng WANG wrote:
Hi, Laurent,
Thanks for you reply.
I have another question about the sample code
"Mesh_cutting_parameterization". When I put in my mesh, I was told
that "FATAL ERROR: Input mesh is not a surface". For the convenience
to find the problem, I attached the mesh I used. What is the requirent
for the input mesh? How to adjust my mesh to be acceptable for the
sample code?
Many thanks!
Defeng
To:
Sent: Monday, December 03, 2007 9:47 PM
Hi Defeng,
CGAL Surface_mesh_parameterization package
can parameterize genus-1 meshes (topological disks).
This package does not provide any algorithm to transform an arbitrary
mesh into a topological disk, the user being responsible for
generating such a cut graph. Nevertheless, we provide a simple
cutting algorithm for the sake of completeness. See details at
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesh_parameterization/Chapter_main.html#Section_39.5
Best regards,
Laurent Saboret
INRIA Sophia-Antipolis
Defeng WANG a écrit :
Hello, CGALers,
Ask one quick question, if I want to parameterize of a genus-3 mesh,
what should I do by using CGAL?
Thanks for any comments.
Best wishes,
Defeng
- Re: [cgal-discuss] Question about mesh simplification, Fernando Cacciola, 12/03/2007
- parameterization of genus-3 mesh, Defeng WANG, 12/03/2007
- Re: [cgal-discuss] parameterization of genus-3 mesh, Laurent Saboret, 12/03/2007
- Re: [cgal-discuss] parameterization of genus-3 mesh, Defeng WANG, 12/03/2007
- Re: [cgal-discuss] parameterization of genus-3 mesh, Laurent Saboret, 12/05/2007
- Re: [cgal-discuss] parameterization of genus-3 mesh, Defeng WANG, 12/06/2007
- Re: [cgal-discuss] parameterization of genus-3 mesh, Laurent Rineau, 12/05/2007
- help - "FATAL ERROR: Input mesh is not a surface", Defeng WANG, 12/04/2007
- Re: [cgal-discuss] help - "FATAL ERROR: Input mesh is not a surface", Defeng WANG, 12/05/2007
- about Input mesh is not a surface, Defeng WANG, 12/05/2007
- Re: [cgal-discuss] parameterization of genus-3 mesh, Pierre Alliez, 12/03/2007
- Re: [cgal-discuss] Question about mesh simplification, Pablo Carneiro Elias, 12/03/2007
