cgal-discuss - Re: [cgal-discuss] Straight_Skeleton_2 Null pointer
  • To: <>
  • Subject: Re: [cgal-discuss] Straight_Skeleton_2 Null pointer
  • Date: Mon, 10 Dec 2007 14:58:20 -0300
  • Organization: Geometry Factory
Hi sinan,
I missed the fact that you had attached "example.poly"
FWIW, I tested the example polygon with CGAL 3.3.1 both patched and unpatched and the skeleton is built correctly (see the attached drawing)
Can you post the entire program (with the #includes and typedefs)? and how exactly are you building it (compiler, options, CGAL libraries used, etc)
Best
Fernando Cacciola
GeometryFactory
Attachment: example.png
Description: PNG image
