- To: <>
- Subject: Re: [cgal-discuss] Straight_Skeleton_2 Null pointer
- Date: Tue, 11 Dec 2007 10:05:52 -0300
- Organization: Geometry Factory
Hi Sinan,
The polygon in data/example.poly has the wrong orientation.
I didn't notice before because the demo program corrects the orientation of polygons on load, but I forgotten it did that.
If you add the following to your example program, right after the example is loaded:
CGAL::Orientation o = CGAL::orientation_2(all_pts, all_pts+(int)vertexCount);
if ( o != CGAL::COUNTERCLOCKWISE )
std::reverse(all_pts,all_pts+(int)vertexCount);
it will work.
Best
Fernando Cacciola
GeometryFactory
- Straight_Skeleton_2 Null pointer, sinan mutlu, 12/10/2007
- Re: [cgal-discuss] Straight_Skeleton_2 Null pointer, Fernando Cacciola, 12/10/2007
- Re: [cgal-discuss] Straight_Skeleton_2 Null pointer, sinan mutlu, 12/11/2007
- Re: [cgal-discuss] Straight_Skeleton_2 Null pointer, Fernando Cacciola, 12/11/2007
