- To:
- Subject: Re: [cgal-discuss] Straight_Skeleton_2 Null pointer
- Date: Tue, 11 Dec 2007 09:50:33 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=FnZHe6WTjR62Uvcn3EWJpVD3OeFsmgCMpp37hj7PBJOlVcDjGLfgkwWSYRNdg9dmwaNaMtz10sIA6FU4cnn3e7BU7ZouocdX3kBeXyLcIb2SA2crTFpZjU2ye//i8ZfGQmTWyMxFRWGSdPoauKAeGbHu227D6Kh2eMDwG+W3/Z8=
Hi Fernando,
I am sending the entire program, but you only can copy the "Straight_skeleton_2.cpp" to your Straight_skeleton_2 example and compile it. I also added some opengl codes in it. Moreover I am compiling it in Visual Studio.2005.
Best Regards,
Sinan Mutlu
On 10/12/2007, Fernando Cacciola <> wrote:
Hi sinan,
I missed the fact that you had attached "example.poly "
FWIW, I tested the example polygon with CGAL 3.3.1 both patched and unpatched
and the skeleton is built correctly (see the attached drawing)
Can you post the entire program (with the #includes and typedefs)? and how
exactly are you building it (compiler, options, CGAL libraries used, etc)
Best
Fernando Cacciola
GeometryFactory
Straight_skeleton_2.rar
Description: application/rar-compressed
- Straight_Skeleton_2 Null pointer, sinan mutlu, 12/10/2007
- Re: [cgal-discuss] Straight_Skeleton_2 Null pointer, Fernando Cacciola, 12/10/2007
- Re: [cgal-discuss] Straight_Skeleton_2 Null pointer, sinan mutlu, 12/11/2007
- Re: [cgal-discuss] Straight_Skeleton_2 Null pointer, Fernando Cacciola, 12/11/2007
