cgal-discuss - Re: [cgal-discuss] CGAL and Ubuntu
  • To:
  • Subject: Re: [cgal-discuss] CGAL and Ubuntu
  • Date: Wed, 12 Dec 2007 10:02:55 +0100
Hi,
>> I found that the command is not g++ but it is "g++-3.3", but I don't know
>> how to tell cgal, use "g++-3.3" and not g++.
> It's strange g++ is not installed if some g++-x.y is. But, you may try (as
> root):
No, it makes sense. The g++ package is kind of a meta package that
depends on the default g++-X.Y package and contains /usr/bin/g++, which
is a symbolic link to the default g++-X.Y binary. If you just want g++,
install g++; if you want a specific g++-X.Y, install g++-X.Y. Simple,
isn't it?
> which g++-3.3
> answer: "path"/g++-3.3 (i.e., linux gives us the path to
> g++-3.3, /usr/local/bin or wherever).
> ln -s "path"/g++-3.3 "path"/g++ (replace "path" with path to g++-3.3).
> (make a "link" to g++-3.3 so now calls to g++ point to it.)
Please don't do this (at least if "path" if /usr/bin). Just install the
g++ package.
(And g++-3.3 is most probably not the compiler that was used to compile
the CGAL libraries on Ubuntu. Hence, you will get into trouble in the
linking stage.)
Joachim
