cgal-discuss - Re: [cgal-discuss] Re: Installing/Configuring CGAL on Visual Studio 2008
  • To:
  • Subject: Re: [cgal-discuss] Re: Installing/Configuring CGAL on Visual Studio 2008
  • Date: Mon, 31 Dec 2007 23:55:17 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=b5TL/GXK6KH3XlJZ9Jbh4Ow29i5yt6KM9EIMWgmsYV2Z9acZ4KTilvyxQ8q2O3k0tUrx5i2MP368aoLH4lEj7QpFS5xE0gJnVg3QIGsSWth/v44dqcObUFMcg8C4kgYa6ARSVuX0JO9uapWvXbT+8LfZFErjSh9/Ve2Y9H7P77Y=;
>Yes I did, they point to the CGALROOT environment variable. I am trying
>to make the demos work but I get an error on build which says that
>following...
First try to run an example instead of direclty running a demo (which uses
QT). The "Polygon" example is a very simple one that you can figure out if
variables are set properly.
Mahmood NT
----- Original Message ----
To:
Sent: Tuesday, January 1, 2008 5:48:41 AM
2008
following...
Project : error PRJ0019: A tool returned an error code from "Performing
Pre-Build Event..."
and the BuildLog.htm says
Creating temporary file "c:\Program
Files\CGAL-3.3.1\demo\Stream_lines_2\Debug\BAT00000130361096.bat" with
contents
@echo off
C:\Qt/bin/moc.exe -o streamlines.moc streamlines.cpp
if errorlevel 1 goto VCReportError
goto VCEnd
:VCReportError
echo Project : error PRJ0019: A tool returned an error code from
"Performing Pre-Build Event..."
exit 1
:VCEnd
Creating command line """c:\Program
Files\CGAL-3.3.1\demo\Stream_lines_2\Debug\BAT00000130361096.bat"""
I have installed Qt through it's windows installer, and the $QTDIR is
set to C:\Qt (which is where is installed on my computer)
-Raza
On Tue, 1 Jan 2008 02:40:02 +0100,
said:
> Hi,
> Did you add it to your 'include' directories?
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Mohammad Raza
http://www.fastmail.fm - Access your email from home and the web
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
