cgal-discuss - Re: [cgal-discuss] Re: Installing/Configuring CGAL on Visual Studio 2008
  • To:
  • Subject: Re: [cgal-discuss] Re: Installing/Configuring CGAL on Visual Studio 2008
  • Date: Wed, 02 Jan 2008 11:57:40 -0600
I got the Polygon example to work, and so did the Boost example code.
But now, I am trying to build that Basic Triangulation example code from
CGAL documentations and it is giving me Linker Errors. Here is the
output from BuildLog.htm
Creating temporary file "c:\Documents and Settings\mraza\My
Documents\Visual Studio
2008\Projects\CGAL_Test2\CGAL_Test2\Debug\RSP00000135323504.rsp" with
contents
/Od /I "C:\Program Files\CGAL-3.3.1\include" /I "C:\Program
Files\CGAL-3.3.1\include\CGAL\config\msvc" /I "C:\Program
Files\CGAL-3.3.1\auxiliary\gmp\include" /I "C:\Program
Files\CGAL-3.3.1\auxiliary\taucs\include" /I "..\include" /I "C:\Program
Files\boost\boost_1_34_1\\" /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D
"_UNICODE" /D "UNICODE" /Gm /EHsc /RTC1 /MDd /Fo"Debug\\"
/Fd"Debug\vc90.pdb" /W3 /c /ZI /TP ".\CGAL_Test2.cpp"
Creating command line "cl.exe @"c:\Documents and Settings\mraza\My
2008\Projects\CGAL_Test2\CGAL_Test2\Debug\RSP00000135323504.rsp" /nologo
/errorReport:prompt"
2008\Projects\CGAL_Test2\CGAL_Test2\Debug\RSP00000235323504.rsp" with
contents
/OUT:"C:\Documents and Settings\mraza\My Documents\Visual Studio
2008\Projects\CGAL_Test2\Debug\CGAL_Test2.exe" /INCREMENTAL
/LIBPATH:"C:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib" /MANIFEST
/MANIFESTFILE:"Debug\CGAL_Test2.exe.intermediate.manifest"
/MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG
/PDB:"C:\Documents and Settings\mraza\My Documents\Visual Studio
2008\Projects\CGAL_Test2\Debug\CGAL_Test2.pdb" /SUBSYSTEM:CONSOLE
/DYNAMICBASE /NXCOMPAT /MACHINE:X86 kernel32.lib user32.lib gdi32.lib
winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib
oleaut32.lib uuid.lib odbc32.lib odbccp32.lib
".\Debug\CGAL_Test2.obj"
".\Debug\stdafx.obj"
".\Debug\CGAL_Test2.exe.embed.manifest.res"
Creating command line "link.exe @"c:\Documents and Settings\mraza\My
2008\Projects\CGAL_Test2\CGAL_Test2\Debug\RSP00000235323504.rsp" /NOLOGO
/ERRORREPORT:PROMPT"
The example code that I am trying to build is
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2/Chapter_main.html
under section 25.4.2.
-M Raza
On Mon, 31 Dec 2007 23:55:17 -0800 (PST), "Mahmood NT"
said:
> >Yes I did, they point to the CGALROOT environment variable. I am trying
> >to make the demos work but I get an error on build which says that
> >following...
> First try to run an example instead of direclty running a demo (which
> uses QT). The "Polygon" example is a very simple one that you can figure
> out if variables are set properly.
> Mahmood NT
> ----- Original Message ----
> From: Mohammad Raza
> To:
> Sent: Tuesday, January 1, 2008 5:48:41 AM
> Studio 2008
> following...
> Project : error PRJ0019: A tool returned an error code from "Performing
> Pre-Build Event..."
> and the BuildLog.htm says
> Creating temporary file "c:\Program
> Files\CGAL-3.3.1\demo\Stream_lines_2\Debug\BAT00000130361096.bat" with
> contents
> @echo off
> C:\Qt/bin/moc.exe -o streamlines.moc streamlines.cpp
> if errorlevel 1 goto VCReportError
> goto VCEnd
> :VCReportError
> echo Project : error PRJ0019: A tool returned an error code from
> "Performing Pre-Build Event..."
> exit 1
> :VCEnd
> Creating command line """c:\Program
> Files\CGAL-3.3.1\demo\Stream_lines_2\Debug\BAT00000130361096.bat"""
> I have installed Qt through it's windows installer, and the $QTDIR is
> set to C:\Qt (which is where is installed on my computer)
> -Raza
> On Tue, 1 Jan 2008 02:40:02 +0100,
> said:
> > Hi,
> > Did you add it to your 'include' directories?
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
> Mohammad Raza
> http://www.fastmail.fm - Access your email from home and the web
> ____________________________________________________________________________________
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile. Try it now.
> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Mohammad Raza
http://www.fastmail.fm - Accessible with your email software
or over the web
