- To:
- Subject: Re: [cgal-discuss] triangulating a 3D polygon
- Date: Tue, 01 Jan 2008 11:51:50 +0100
use Triangulation_euclidean_traits_xy_3 ....
Carefull I am not sure how predicates in this traits are filtered
Pierre Alliez wrote:
hi all,
Suppose I intersect the edges of a 3D convex polyhedron with a plane. This gives me a set of points. I would like to obtain a 2D triangulation of this point set (any triangulation). Any idea how do achieve this easily? I thought of computing the convex hull of this point set, but this may be an overkill.
Precision: I know the "surface interpolation" trick which turns the voronoi-cell-plane-intersection problem into a Power diagram from the surface interpolation component - and want to try another solution.
thanks!
Pierre
http://www-sop.inria.fr/geometrica/team/Pierre.Alliez/
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
- Re: [cgal-discuss] triangulating a 3D polygon, Mariette Yvinec, 01/01/2008
