cgal-discuss - RE: [cgal-discuss] Shell-like iteration in Polyhedra class
  • To: "" <>
  • Subject: RE: [cgal-discuss] Shell-like iteration in Polyhedra class
  • Date: Tue, 8 Jan 2008 13:17:31 -0800
  • Accept-language: en-US, en-CA
  • Acceptlanguage: en-US, en-CA
Hi Peter,
Thanks for your response.
Just to reaffirm what you have said - Polyhedron_3 has no way of
differentiating between facets when there is more than one 2-manifold
boundary (in a single Polyhedron_3). Or, put in another way, Polyhedron_3
does not provide a means of iterating through facets of individual boundaries.
Stephen
-----Original Message-----
[mailto:]
Sent: January-08-08 12:32 PM
To:
Subject: Re: [cgal-discuss] Shell-like iteration in Polyhedra class
Hi Stephen,
the Polyhedron_3 data structure does not provide iteration over shells.
The reason is that Polyhedron_3 is designed to provide the typical mesh
operations and nothing else. From a mesh point of view shells and
volumes are not needed - you only think of boundaries (usally exactly
one two-manifold boundary). The advantage is, that the data structure of
Polyhedron_3 is not as complicated as the data structure of
Nef_polyhedron_3. It can be handled more efficiently.
Peter
On Tue, 2008-01-08 at 10:51 -0800, Stephen Wong wrote:
> Hello,
> Nef Polyhedra has a well-defined set of volume and shell iterators.
> However, after converting Nef Polyhedra back to B-rep Polyhedra using
> Nef_polyhedron_3<>::convert_to_Polyhedron() (after a Boolean
> operation, for example), the Polyhedron class does not have similar
> iterators.
> How can I iterate the faces between different “volumes” or “shells” in
> a Polyhedron?
> A concrete example:
> Nef polyhedron N1 is a box with lower left (0,0,0) and upper right
> (3,3,3)
> Nef polyhedron N2 is a box with lower left (1,1,1) and upper right
> (2,2,2)
> N1 -= N2 ; // difference boolean operator
> N1.convert_to_Polyhedron() ;
> This resultant Polyhedron has an outer shell and an inner shell
> bounding the void inside the cube. I want to access facets for each
> shell of the Polyhedron. The function facets_begin() provided in the
> Polyhedron class iterates through all facets in the polyhedron, i.e.
> all shells without distinction.
> Thanks,
> Stephen Wong
