cgal-discuss - RE: [cgal-discuss] Shell-like iteration in Polyhedra class
  • To: "" <>
  • Subject: RE: [cgal-discuss] Shell-like iteration in Polyhedra class
  • Date: Tue, 8 Jan 2008 17:45:46 -0800
  • Accept-language: en-US, en-CA
  • Acceptlanguage: en-US, en-CA
Hi Peter,
Do you know anything about the undocumented function
convert_inner_shell_to_polyhedron() in Nef_polyhedron_3? I am still looking
for a way to iterate through shells, and came across this function in
Nef_polyhedron_3.h.
Thank you again,
Stephen
-----Original Message-----
[mailto:]
Sent: January-08-08 1:31 PM
To:
That's right. There is no notion of separate boundaries in Polyhedron_3.
On Tue, 2008-01-08 at 13:17 -0800, Stephen Wong wrote:
> Hi Peter,
> Thanks for your response.
> Just to reaffirm what you have said - Polyhedron_3 has no way of
> differentiating between facets when there is more than one 2-manifold
> boundary (in a single Polyhedron_3). Or, put in another way, Polyhedron_3
> does not provide a means of iterating through facets of individual
> boundaries.
> Stephen
> From: Peter Hachenberger
> [mailto:]
> Sent: January-08-08 12:32 PM
> To:
> Subject: Re: [cgal-discuss] Shell-like iteration in Polyhedra class
> Hi Stephen,
> the Polyhedron_3 data structure does not provide iteration over shells.
> The reason is that Polyhedron_3 is designed to provide the typical mesh
> operations and nothing else. From a mesh point of view shells and
> volumes are not needed - you only think of boundaries (usally exactly
> one two-manifold boundary). The advantage is, that the data structure of
> Polyhedron_3 is not as complicated as the data structure of
> Nef_polyhedron_3. It can be handled more efficiently.
> Peter
> On Tue, 2008-01-08 at 10:51 -0800, Stephen Wong wrote:
> > Hello,
> > Nef Polyhedra has a well-defined set of volume and shell iterators.
> > However, after converting Nef Polyhedra back to B-rep Polyhedra using
> > Nef_polyhedron_3<>::convert_to_Polyhedron() (after a Boolean
> > operation, for example), the Polyhedron class does not have similar
> > iterators.
> > How can I iterate the faces between different “volumes” or “shells” in
> > a Polyhedron?
> > A concrete example:
> > Nef polyhedron N1 is a box with lower left (0,0,0) and upper right
> > (3,3,3)
> > Nef polyhedron N2 is a box with lower left (1,1,1) and upper right
> > (2,2,2)
> > N1 -= N2 ; // difference boolean operator
> > N1.convert_to_Polyhedron() ;
> > This resultant Polyhedron has an outer shell and an inner shell
> > bounding the void inside the cube. I want to access facets for each
> > shell of the Polyhedron. The function facets_begin() provided in the
> > Polyhedron class iterates through all facets in the polyhedron, i.e.
> > all shells without distinction.
> > Thanks,
> > Stephen Wong
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
