- To:
- Subject: RE: [cgal-discuss] Shell-like iteration in Polyhedra class
- Date: Wed, 09 Jan 2008 12:00:09 +0100
This function converts one shell of the polyhedron into a Polyhedron_3.
So, if that helps you, you can convert the shells separately into
Polyhedron_3s and work on them.
Peter
On Tue, 2008-01-08 at 17:45 -0800, Stephen Wong wrote:
> Hi Peter,
> Do you know anything about the undocumented function
> convert_inner_shell_to_polyhedron() in Nef_polyhedron_3? I am still
> looking for a way to iterate through shells, and came across this function
> in Nef_polyhedron_3.h.
> Thank you again,
> Stephen
> -----Original Message-----
> From: Peter Hachenberger
> [mailto:]
> Sent: January-08-08 1:31 PM
> To:
> That's right. There is no notion of separate boundaries in Polyhedron_3.
> On Tue, 2008-01-08 at 13:17 -0800, Stephen Wong wrote:
> > Hi Peter,
> > Thanks for your response.
> > Just to reaffirm what you have said - Polyhedron_3 has no way of
> > differentiating between facets when there is more than one 2-manifold
> > boundary (in a single Polyhedron_3). Or, put in another way,
> > Polyhedron_3 does not provide a means of iterating through facets of
> > individual boundaries.
> > Stephen
> > [mailto:]
> > Sent: January-08-08 12:32 PM
> > To:
> > Subject: Re: [cgal-discuss] Shell-like iteration in Polyhedra class
> > Hi Stephen,
> > the Polyhedron_3 data structure does not provide iteration over shells.
> > The reason is that Polyhedron_3 is designed to provide the typical mesh
> > operations and nothing else. From a mesh point of view shells and
> > volumes are not needed - you only think of boundaries (usally exactly
> > one two-manifold boundary). The advantage is, that the data structure of
> > Polyhedron_3 is not as complicated as the data structure of
> > Nef_polyhedron_3. It can be handled more efficiently.
> > Peter
> > On Tue, 2008-01-08 at 10:51 -0800, Stephen Wong wrote:
> > > Hello,
> > > Nef Polyhedra has a well-defined set of volume and shell iterators.
> > > However, after converting Nef Polyhedra back to B-rep Polyhedra using
> > > Nef_polyhedron_3<>::convert_to_Polyhedron() (after a Boolean
> > > operation, for example), the Polyhedron class does not have similar
> > > iterators.
> > > How can I iterate the faces between different “volumes” or “shells” in
> > > a Polyhedron?
> > > A concrete example:
> > > Nef polyhedron N1 is a box with lower left (0,0,0) and upper right
> > > (3,3,3)
> > > Nef polyhedron N2 is a box with lower left (1,1,1) and upper right
> > > (2,2,2)
> > > N1 -= N2 ; // difference boolean operator
> > > N1.convert_to_Polyhedron() ;
> > > This resultant Polyhedron has an outer shell and an inner shell
> > > bounding the void inside the cube. I want to access facets for each
> > > shell of the Polyhedron. The function facets_begin() provided in the
> > > Polyhedron class iterates through all facets in the polyhedron, i.e.
> > > all shells without distinction.
> > > Thanks,
> > > Stephen Wong
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
- Shell-like iteration in Polyhedra class, Stephen Wong, 01/08/2008
- Re: [cgal-discuss] Shell-like iteration in Polyhedra class, Peter Hachenberger, 01/08/2008
- RE: [cgal-discuss] Shell-like iteration in Polyhedra class, Stephen Wong, 01/08/2008
- RE: [cgal-discuss] Shell-like iteration in Polyhedra class, Peter Hachenberger, 01/08/2008
- RE: [cgal-discuss] Shell-like iteration in Polyhedra class, Stephen Wong, 01/09/2008
- RE: [cgal-discuss] Shell-like iteration in Polyhedra class, Peter Hachenberger, 01/09/2008
