cgal-discuss - voronoi of points in an extent
  • To:
  • Subject: voronoi of points in an extent
  • Date: Sat, 19 Jan 2008 18:03:08 +0100
hi all,
i would like to applicate voronoi with points.
this part works fine by this code :
#include <CGAL/basic.h>
// standard includes
#include <iostream>
#include <fstream>
#include <cassert>
// includes for defining the Voronoi diagram adaptor
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Voronoi_diagram_2.h>
#include <CGAL/Delaunay_triangulation_adaptation_traits_2.h>
#include <CGAL/Delaunay_triangulation_adaptation_policies_2.h>
// typedefs for defining the adaptor
typedef CGAL::Exact_predicates_inexact_constructions_kernel
K;
typedef CGAL::Delaunay_triangulation_2<K>
DT;
typedef CGAL::Delaunay_triangulation_adaptation_traits_2<DT>
AT;
typedef CGAL::Delaunay_triangulation_caching_degeneracy_removal_policy_2<DT>
AP;
typedef CGAL::Voronoi_diagram_2<DT,AT,AP>
VD;
// typedef for the result type of the point location
typedef AT::Site_2 Site_2;
typedef AT::Point_2 Point_2;
typedef VD::Locate_result Locate_result;
typedef VD::Vertex_handle Vertex_handle;
typedef VD::Face_handle Face_handle;
typedef VD::Halfedge_handle Halfedge_handle;
typedef VD::Ccb_halfedge_circulator Ccb_halfedge_circulator;
void print_endpoint(Halfedge_handle e, bool is_src) {
std::cout << "\t";
if ( is_src ) {
if ( e->has_source() ) std::cout << e->source()->point() << std::endl;
else std::cout << "point at infinity" << std::endl;
} else {
if ( e->has_target() ) std::cout << e->target()->point() << std::endl;
int main()
VD vd;
VD::Face_iterator f;
Point_2 *p;
for(int i=0;i<10;i++)
p=new Point_2(rand()%200,rand()%200);
vd.insert(*p);
delete p;
p=0;
Ccb_halfedge_circulator ec_start,ec;
for(f=vd.faces_begin();f!=vd.faces_end();f++)
std::cout << "\n\n";
ec_start = (*f).outer_ccb();
ec = ec_start;
do {
print_endpoint(ec, false);
} while ( ++ec != ec_start );
return 0;
My problem is :
faces in corners has Halfedges with points at infinity.
how can i give an extent to voronoi (for exemple a rectangle), then this
faces can complete their Halfedges with points at infinity with intersection
with the extent?
thank you for your help
  • voronoi of points in an extent, bendaoud_med, 01/19/2008
