- To:
- Subject: Re: [cgal-discuss]The brittle VS series compilers
- Date: Sat, 19 Jan 2008 22:31:40 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=APKQ8KEwUmYu6kw5d3MzRAK0NwETV41rcpv7Hg1ngBtMhtuLjudi5kP4+VKEXV1v3++F+C/OmvVcqMFNkcFB32qAQdh7+zsv0ImpQq1OVX590ql1HSEyO52vrsNFSo2LkCIMmUlZx2VRMNuWfj8nr1CF774gmuVebdFkSp+2Vdo=;
> I got a fatal error C1001.
Hi max,
what is the detail of message. ICEs will show the the line of error
(...\...\maic.c line NNN)
Mahmood NT
----- Original Message ----
To:
Sent: Saturday, January 19, 2008 4:45:43 PM
Subject: [cgal-discuss]The brittle VS series compilers
Hi all,
With just several line of code, I get the VS2005 compiler
choked.
The code:
template<class Polyhedron_3>
std::vector<CGAL::Polygon_2<typename Polyhedron_3::Traits> >
Intersect_polyhedron_with_xoy( const Polyhedron_3& P )
std::vector<CGAL::Polygon_2<typename Polyhedron_3::Traits> > r;
return r;
typedef CGAL::Extended_homogeneous<CGAL::Gmpzf> Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron_3;
Polyhedron_3 P;
Intersect_polyhedron_with_xoy(P);
Is the MS compiler so brittle?
B/Rgds
Max
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
- Re: [cgal-discuss]The brittle VS series compilers, Mahmood NT, 01/20/2008
- Re: Re: [cgal-discuss]The brittle VS series compilers, Max, 01/20/2008
- <Possible follow-up(s)>
- Re: Re: [cgal-discuss]The brittle VS series compilers, Mahmood NT, 01/21/2008
- Re: Re: Re: [cgal-discuss]The brittle VS series compilers, Max, 01/21/2008
