cgal-discuss - Re: Re: Re: [cgal-discuss]The brittle VS series compilers
  • To: "" <>
  • Subject: Re: Re: Re: [cgal-discuss]The brittle VS series compilers
  • Date: Mon, 21 Jan 2008 15:30:49 +0800
  • Disposition-notification-to: "Max" <>
  • Organization: LoadCom
Hello Mahmood,
Thank you for your hints.
B/Rgds
Max
>>..\interface_polyhedron.cpp(176) : fatal error C1001: An internal error has
>>occurred in the compiler.
>>(compiler file 'msc1.cpp', line 1393)
>Hi max,
>This is a reported bug to msdn. Thing is, microsoft annouces for one service
>pack for a special VS version. After that, if some one find a bug and report
>to microsoft, the solution will be in the next version of VS.
>Templates (typedef and typename) are bugy in VS. You can fix the problem (if
>you want to use 2005) by exploring your code and reduce some additional and
>unnecessary typedefs. I had the same problem with VS2003 (ICE after SP1) and
>when I reduce the typedefs, I finally beat it.
>Here is the link of my own experience
>http://forums.microsoft.com/msdn/showpost.aspx?pageindex=1&siteid=1&postid=2395279&sb=0&d=1&at=7&ft=11&tf=0&pageid=0
> maybe it give you a cue
>Mahmood NT
>----- Original Message ----
>From: Max
>To:
>Sent: Sunday, January 20, 2008 4:47:14 PM
>Subject: Re: Re: [cgal-discuss]The brittle VS series compilers
>Hi Mahmood
>the msg is as follows:
>To work around this problem, try simplifying or changing the program near
>the locations listed above.
>Please choose the Technical Support command on the Visual C++
>Help menu, or open the Technical Support help file for more information
>B/Rgds
>Max
>>> I got a fatal error C1001.
>>Hi max,
>>what is the detail of message. ICEs will show the the line of error
>>(...\...\maic.c line NNN)
>>Mahmood NT
>>From: Max
>>To:
>>Sent: Saturday, January 19, 2008 4:45:43 PM
>>Subject: [cgal-discuss]The brittle VS series compilers
>>Hi all,
>>With just several line of code, I get the VS2005 compiler
>>choked.
>>The code:
>>template<class Polyhedron_3>
>>std::vector<CGAL::Polygon_2<typename Polyhedron_3::Traits> >
>>Intersect_polyhedron_with_xoy( const Polyhedron_3& P )
>> std::vector<CGAL::Polygon_2<typename Polyhedron_3::Traits> > r;
>> return r;
>>typedef CGAL::Extended_homogeneous<CGAL::Gmpzf> Kernel;
>>typedef CGAL::Polyhedron_3<Kernel> Polyhedron_3;
>>Polyhedron_3 P;
>>Intersect_polyhedron_with_xoy(P);
>>Is the MS compiler so brittle?
>>B/Rgds
>>Max
>>You are currently subscribed to cgal-discuss.
>>To unsubscribe or access the archives, go to
>>https://lists-sop.inria.fr/wws/info/cgal-discuss
>> ____________________________________________________________________________________
>>Never miss a thing. Make Yahoo your home page.
>>http://www.yahoo.com/r/hs
