- To: "" <>
- Subject: Re: Re: [cgal-discuss]The brittle VS series compilers
- Date: Sun, 20 Jan 2008 21:17:14 +0800
- Disposition-notification-to: "Max" <>
- Organization: LoadCom
Hi Mahmood
the msg is as follows:
..\interface_polyhedron.cpp(176) : fatal error C1001: An internal error has
occurred in the compiler.
(compiler file 'msc1.cpp', line 1393)
To work around this problem, try simplifying or changing the program near
the locations listed above.
Please choose the Technical Support command on the Visual C++
Help menu, or open the Technical Support help file for more information
B/Rgds
Max
>> I got a fatal error C1001.
>Hi max,
>what is the detail of message. ICEs will show the the line of error
>(...\...\maic.c line NNN)
>Mahmood NT
>----- Original Message ----
>From: Max
>To:
>Sent: Saturday, January 19, 2008 4:45:43 PM
>Subject: [cgal-discuss]The brittle VS series compilers
>Hi all,
>With just several line of code, I get the VS2005 compiler
>choked.
>The code:
>template<class Polyhedron_3>
>std::vector<CGAL::Polygon_2<typename Polyhedron_3::Traits> >
>Intersect_polyhedron_with_xoy( const Polyhedron_3& P )
> std::vector<CGAL::Polygon_2<typename Polyhedron_3::Traits> > r;
> return r;
>typedef CGAL::Extended_homogeneous<CGAL::Gmpzf> Kernel;
>typedef CGAL::Polyhedron_3<Kernel> Polyhedron_3;
>Polyhedron_3 P;
>Intersect_polyhedron_with_xoy(P);
>Is the MS compiler so brittle?
>B/Rgds
>Max
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
> ____________________________________________________________________________________
>Never miss a thing. Make Yahoo your home page.
>http://www.yahoo.com/r/hs
- Re: [cgal-discuss]The brittle VS series compilers, Mahmood NT, 01/20/2008
- Re: Re: [cgal-discuss]The brittle VS series compilers, Max, 01/20/2008
- <Possible follow-up(s)>
- Re: Re: [cgal-discuss]The brittle VS series compilers, Mahmood NT, 01/21/2008
- Re: Re: Re: [cgal-discuss]The brittle VS series compilers, Max, 01/21/2008
