- To: "" <>
- Subject: Boolean Operations (Nef_3) creating thin (e-16) slabs
- Date: Mon, 21 Jan 2008 12:51:07 -0800
- Accept-language: en-US, en-CA
- Acceptlanguage: en-US, en-CA
Hello, I’m finding that since CGAL is using exact
representations of numbers in Boolean operations, working with datasets with
floating-point data can produce correct, but less-than-desirable results.
In one example, I have two cubes, one inside another, with two faces flush
against each other. Since the numerical representation is double, during
conversion to Gmpq or Gmpz, they are not the same plane and, thus after a CSG subtraction,
a thin 1.0e-16 width slab is left (instead of removing part of that face).
In another case the slab was as small as 1.0e-300. A numerical example is as such: Cube1 (0,0,0) – (3,3,3) Cube2 (1.0e-10, 0, 0) – (2, 2, 2) When Cube1 minus cube2 is performed, a slab of width 1.0e-10
is left. Is there a way for Nef_polyhedron_3 to remove very thin
slabs based on a certain tolerance value? Rounding the input values will
not always solve this problem. Thanks. Stephen |
- Boolean Operations (Nef_3) creating thin (e-16) slabs, Stephen Wong, 01/21/2008
- Re: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16) slabs, Bart Janssens, 01/22/2008
- RE: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16) slabs, Stephen Wong, 01/25/2008
- RE: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16) slabs, Peter Hachenberger, 01/25/2008
- Re: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16) slabs, Peter Hachenberger, 01/22/2008
