- To:
- Subject: RE: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16) slabs
- Date: Fri, 25 Jan 2008 11:41:20 +0100
Hi Stephen,
Bart and I had some email chat about that. He basically removed all
those geometric assertion and it seems to work.
Peter
On Thu, 2008-01-24 at 18:42 -0800, Stephen Wong wrote:
> Hi Bart,
> Thanks for your help. I have tried to implement a threshold numbertype
> based on Gmpq, as you have done. However, when execution of Boolean
> operations, CGAL fails at non-assertions on some geometries. Have you
> experienced this as well? The amount of success I have had with removing
> "thin slabs" using this method is limited - most of the time, I get
> failures in CGAL's Nef_polyhedron_3.
> Regards,
> Stephen
> -----Original Message-----
> From:
> [mailto:]
> On Behalf Of Bart Janssens
> Sent: January-21-08 11:04 PM
> To:
> Subject: Re: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16)
> slabs
> On 1/21/08, Stephen Wong
> wrote:
> > Is there a way for Nef_polyhedron_3 to remove very thin slabs based on a
> > certain tolerance value? Rounding the input values will not always solve
> > this problem.
> In K-3D, we solved this by using a custom number type, that compares
> values up to a threshold. See
> http://k3d.svn.sourceforge.net/viewvc/k3d/trunk/modules/booleans/threshold_number.h
> for an example.
> When using this approach, you may run into some failed assertions, see
> http://www.k-3d.org/wiki/CGAL_Boolean_Operations for a patch to remove
> the ones I encountered.
> regards,
> Bart Janssens
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- Boolean Operations (Nef_3) creating thin (e-16) slabs, Stephen Wong, 01/21/2008
- Re: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16) slabs, Bart Janssens, 01/22/2008
- RE: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16) slabs, Stephen Wong, 01/25/2008
- RE: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16) slabs, Peter Hachenberger, 01/25/2008
- Re: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16) slabs, Peter Hachenberger, 01/22/2008
