cgal-discuss - RE: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16) slabs
  • To: "" <>
  • Subject: RE: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16) slabs
  • Date: Thu, 24 Jan 2008 18:42:46 -0800
  • Accept-language: en-US, en-CA
  • Acceptlanguage: en-US, en-CA
Hi Bart,
Thanks for your help. I have tried to implement a threshold numbertype based
on Gmpq, as you have done. However, when execution of Boolean operations,
CGAL fails at non-assertions on some geometries. Have you experienced this
as well? The amount of success I have had with removing "thin slabs" using
this method is limited - most of the time, I get failures in CGAL's
Nef_polyhedron_3.
Regards,
Stephen
-----Original Message-----
[mailto:]
On Behalf Of Bart Janssens
Sent: January-21-08 11:04 PM
To:
Subject: Re: [cgal-discuss] Boolean Operations (Nef_3) creating thin (e-16)
slabs
On 1/21/08, Stephen Wong
wrote:
> Is there a way for Nef_polyhedron_3 to remove very thin slabs based on a
> certain tolerance value? Rounding the input values will not always solve
> this problem.
In K-3D, we solved this by using a custom number type, that compares
values up to a threshold. See
http://k3d.svn.sourceforge.net/viewvc/k3d/trunk/modules/booleans/threshold_number.h
for an example.
When using this approach, you may run into some failed assertions, see
http://www.k-3d.org/wiki/CGAL_Boolean_Operations for a patch to remove
the ones I encountered.
regards,
Bart Janssens
