- To:
- Subject: Re: Re: [cgal-discuss] how to do that?
- Date: Tue, 22 Jan 2008 18:38:21 +0100 (CET)
- Importance: Normal
Hello,
Using function draw_dual of triangulation_2 you recover objects which are
lines, segments and rays. Then use Intersection function to get a set of
segments.
typedef CGAL::Iso_rectangle_2<YOUR_KERNEL> Rectangle;
typedef CGAL::Segment_2<YOUR_KERNEL> Segment;
typedef CGAL::Ray_2<KernelCD> Ray;
typedef CGAL::Line_2<KernelCD> Line;
typedef std::list<Ray> RayList;
typedef std::list<Line> LineList;
typedef std::list<Segment> SegmentList;
struct Voronoi_recup { //Class using stream to get the voronoi diagram
RayList quR;
LineList quL;
SegmentList quS;
Voronoi_recup() {quR.clear();quL.clear();quS.clear();}
void operator<<(const Ray p){quR.insert(quR.begin(),p);}
void operator<<(const Line p){quL.insert(quL.begin(),p);}
void operator<<(const Segment p){quS.insert(quS.begin(),p);}
YOUR_TRIANGULATION T;
Voronoi_recup vor;
T.draw_dual(vor);
SegmentList Seglist ;
CGAL::Object obj_cgal = CGAL::intersection(YOUR_OBJECT,bbox);
Segment s;
if (CGAL::assign(s, obj_cgal))
Seglist.push_back(s);
Best,
Sebastien
> hi,
> thank you for your response, but if i have an infinity vertex i should
> find the intersection of its halfedge and my box then add this vertex at
> the face.
> but the intersection function don't accept halfedge in parametres.
> So, i don't know how can i do that !
> my goal is to find of each point inserted in voronoi his cell (e.g.a
> polygone).
> Best,
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: Re: [cgal-discuss] how to do that?, bendaoud_med, 01/22/2008
- Re: Re: [cgal-discuss] how to do that?, Sebastien . Loriot, 01/22/2008
- Re:Re: Re: [cgal-discuss] how to do that?, hds, 01/23/2008
- Re:Re: Re: [cgal-discuss] how to do that?, Sebastien . Loriot, 01/23/2008
- <Possible follow-up(s)>
- Re: Re:Re: Re: [cgal-discuss] how to do that?, bendaoud_med, 01/23/2008
- Problems with Vector_3, Jens K. Becker, 01/24/2008
- RE: [cgal-discuss] Problems with Vector_3, Stephen Wong, 01/24/2008
- Re: [cgal-discuss] Problems with Vector_3, Andreas Fabri, 01/24/2008
- Re: [cgal-discuss] Problems with Vector_3, Jens K. Becker, 01/24/2008
