- To:
- Subject: Re: [cgal-discuss] Problems with Vector_3
- Date: Thu, 24 Jan 2008 21:19:02 +0100
You all were right and I should have looked at that first. I really did use a
homogeneous kernel with Gmpz so that could not work. I must have changed that
for whatever reason at one point and then forgot about it.
Thanks very much for the help, that would have taken me ages to find out!
Jens
Dr. J.K. Becker
University of Tuebingen - Institute for Geoscience
Sigwartst. 10 - 72076 Tuebingen (Germany)
Tel.: ++49 7071 29 73139 Fax: +49 7071 5059
web: http://www.jkbecker.de
Quoting "Jens K. Becker"
Hi all,
I have a problem with Vector_3:
Apparently I can not initialize a Vector_3 (CGAL3.3.1, GMP and boost support)
with doubles that are between 1 and -1 (1>x<-1, 0 works though).
This is an example:
std::cout<<Vector_3(0.1,0.9,0.1) results in the output 0 0 0 1
std::cout<<Vector_3(1,1,1) results in the output 1 1 1 1
With an earlier version of CGAL that worked fine, though I am not sure if it is
CGAl or my linux version (I changed it recently).
I have no idea what to do anymore, any ideas anybody?
Thanks for your help,
Jens
Dr. J.K. Becker
- Re: Re: [cgal-discuss] how to do that?, bendaoud_med, 01/22/2008
- Re: Re: [cgal-discuss] how to do that?, Sebastien . Loriot, 01/22/2008
- Re:Re: Re: [cgal-discuss] how to do that?, hds, 01/23/2008
- Re:Re: Re: [cgal-discuss] how to do that?, Sebastien . Loriot, 01/23/2008
- <Possible follow-up(s)>
- Re: Re:Re: Re: [cgal-discuss] how to do that?, bendaoud_med, 01/23/2008
- Problems with Vector_3, Jens K. Becker, 01/24/2008
- RE: [cgal-discuss] Problems with Vector_3, Stephen Wong, 01/24/2008
- Re: [cgal-discuss] Problems with Vector_3, Andreas Fabri, 01/24/2008
- Re: [cgal-discuss] Problems with Vector_3, Jens K. Becker, 01/24/2008
