- To:
- Subject: Problems with Vector_3
- Date: Thu, 24 Jan 2008 19:31:47 +0100
Hi all,
I have a problem with Vector_3:
Apparently I can not initialize a Vector_3 (CGAL3.3.1, GMP and boost support)
with doubles that are between 1 and -1 (1>x<-1, 0 works though).
This is an example:
std::cout<<Vector_3(0.1,0.9,0.1) results in the output 0 0 0 1
std::cout<<Vector_3(1,1,1) results in the output 1 1 1 1
With an earlier version of CGAL that worked fine, though I am not sure if it is
CGAl or my linux version (I changed it recently).
I have no idea what to do anymore, any ideas anybody?
Thanks for your help,
Jens
Dr. J.K. Becker
University of Tuebingen - Institute for Geoscience
Sigwartst. 10 - 72076 Tuebingen (Germany)
Tel.: ++49 7071 29 73139 Fax: +49 7071 5059
web: http://www.jkbecker.de
- Re: Re: [cgal-discuss] how to do that?, bendaoud_med, 01/22/2008
- Re: Re: [cgal-discuss] how to do that?, Sebastien . Loriot, 01/22/2008
- Re:Re: Re: [cgal-discuss] how to do that?, hds, 01/23/2008
- Re:Re: Re: [cgal-discuss] how to do that?, Sebastien . Loriot, 01/23/2008
- <Possible follow-up(s)>
- Re: Re:Re: Re: [cgal-discuss] how to do that?, bendaoud_med, 01/23/2008
- Problems with Vector_3, Jens K. Becker, 01/24/2008
- RE: [cgal-discuss] Problems with Vector_3, Stephen Wong, 01/24/2008
- Re: [cgal-discuss] Problems with Vector_3, Andreas Fabri, 01/24/2008
- Re: [cgal-discuss] Problems with Vector_3, Jens K. Becker, 01/24/2008
