Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a (non-manifold) Nef_polyhedron?
- To:
- Subject: Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a (non-manifold) Nef_polyhedron?
- Date: Mon, 04 Feb 2008 16:58:26 +0100
> My question is: How can I mannualy (with code) construct a (non-manifold)
> Nef_polyhedron given a set of vertices and facets in 3D?
Actually, just as you tried. I hope that the number type makes the
difference. We'll see.
> Another question further: After the construction, how can I get a group
> of manifold Polyhedron_3 as a "regularization" of this Nef_3?
You mean, you want to have a separate Nef_3 for every solid in a single
given Nef_3? Have I already given you code for extracting a boundary
from a Nef_3?
Peter
- Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, (continued)
- Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Peter Hachenberger, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Peter Hachenberger, 02/07/2008
- Re: Re:[cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a (non-manifold) Nef_polyhedron?, Peter Hachenberger, 02/04/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a(non-manifold) Nef_polyhedron?, Max, 02/11/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a(non-manifold) Nef_polyhedron?, Peter Hachenberger, 02/11/2008
