cgal-discuss - CGAL and Boost Graph lib
  • To:
  • Subject: CGAL and Boost Graph lib
  • Date: Wed, 6 Feb 2008 13:17:15 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=NSB9sf5FBJ2mZhJsojk/+Sf3OzQBK36qmvPFCEwaXlao0PzJB7jYnnlZExpm368NhhPFvNIvjt2Rr7rV2tcyEge8UI27IKNN5+ZIdum+tFPs5YLsfM8kMftUfZ7RcR7ONi2upS9S77vrEHrHxOVhOaytgJxy92YYTAplPBwZejE=
Hi
I tried to use CGAL whit Boost Graph library but I've a problem when I modify the features of triangulation.
My code is:
typedef Is_finite<Triangulation> Filter;
typedef boost::filtered_graph<Triangulation,Filter,Filter> Finite_triangulation;
typedef boost::graph_traits<Finite_triangulation>::vertex_descriptor vertex_descriptor;
typedef boost::graph_traits<Finite_triangulation>::vertex_iterator vertex_iterator;
typedef boost::graph_traits<Finite_triangulation>::edge_descriptor edge_descriptor;
typedef boost::graph_traits<Finite_triangulation>::edge_iterator edge_iterator;
int main(int,char*[])
  Triangulation t;
  Filter is_finite(t);
  Finite_triangulation ft(t, is_finite, is_finite);  //graph
  t.insert(Point(0.4, 1));
  t.insert(Point(1, 0.3));
  t.insert(Point(0.0, -0.9));
  t.insert(Point(-1, 0));
  t.insert(Point(1, 2));
  boost::property_map<Triangulation,boost::edge_weight_t>::type weight_map=get(boost::edge_weight,ft);
  edge_iterator eit,eend;
for (boost::tie(eit,eend)=boost::edges(ft); eit!=eend; ++eit)
     std::cout << "PESO: " << get(weight_map,*eit) << "\n";
     put(weight_map,*eit ,100);
     std::cout << "PESO2: " << get(weight_map,*eit) << "\n";
return 0;
at compile time the reply is: "property_map.hpp:319: error: invalid lvalue in assignment"
associated at "put" function.
Why "get" do right and put no?Can help me??
Best regards
-Bombielfi-
