Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion
- To:
- Subject: Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion
- Date: Wed, 06 Feb 2008 13:07:41 +0100
I might have asked you this before, but why do you need halfspaces? If
you only need halfspaces to perform intersections, then you don't need
the extended kernels. I wrote an intersection routine that intersects a
halfspace with a Nef polyhedron without constructing the halfspace
explicitly.
Peter
On Wed, 2008-02-06 at 09:01 +0800, Max wrote:
> Hello Peter
> From what I get from your mail msg's, AFAIUC, there's
> the following facts with relate to Nef_3:
> 1. To use half-space nef_3 ctor such as
> Nef_polyhedron_3 N(Plane_3(1, 0, 0, -1), Nef_polyhedron_3::INCLUDED);
> one should use extended kernel;
> 2. Don't use inexact kernels with Nef_3;
> 3. To play with Nef_3 with double type coordinates, one should
> use SNC_indexed_items as the 2nd template parameter in instantiating
> a Nef_3 type;
> 4. Extended kernels do not work together with SNC_indexed_items.
> It seems that there's no choice, of combinition of Nef_3/kernel, for me
> to meet these needs:
> a) I need the half-space Nef_3 ctor; (that means I should used extended
> kernel)
> b) my coordinates is double type; (that means I should use
> SNC_indexed_items, but it's
> incompatible with extended kernel)
> So this seems to be a deadlock. Is there any solution?
> Many thanks for your help, Peter.
> B/Rgds
> Max
- Re: [cgal-discuss][Nef_polyhedron]A more complex but still simple question, (continued)
- Re: [cgal-discuss][Nef_polyhedron]A more complex but still simple question, Peter Hachenberger, 02/04/2008
- Re: Re: [cgal-discuss][Nef_polyhedron]A more complex but still simplequestion, Max, 02/05/2008
- Re: Re: [cgal-discuss][Nef_polyhedron]A more complex but still simplequestion, Peter Hachenberger, 02/05/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex but stillsimplequestion, Max, 02/05/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex but stillsimplequestion, Peter Hachenberger, 02/05/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, Max, 02/05/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, Max, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, Peter Hachenberger, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Max, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Peter Hachenberger, 02/06/2008
- RE: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Stephen Wong, 02/06/2008
- Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Peter Hachenberger, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Peter Hachenberger, 02/07/2008
