- To:
- Subject: Re: [cgal-discuss] Kinetic_data_structures... some questions
- Date: Thu, 7 Feb 2008 23:47:06 -0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:from:to:in-reply-to:content-type:content-transfer-encoding:mime-version:subject:date:references:x-mailer; b=J3bl1X9pEzwHJRkmEjbeHTeLmwmRsxgwTvbyTLGlBQTTpBemR2LrOhB3Zwm5hyvFQE2VZSNDtbbtkYLssacyCYEavyecJ0Lf5QcFMLOXxb5Vam/MlDs3wpTVljfwzk2SlkLsrkixiLJusVF+pHreRvze5eFAIB2Z0Txy2Ww4w2U=
Thanks for reply. But "CGAL_USE_BOOST_PROGRAM_OPTIONS" preprocessor is not defined. During debugging, the program skips that section.In that case set the "file" string variable at the start of main to the name of the file. If that variable is empty it just generates some points randomly. The file format is quite simple: a series of lines like
polynomial for x, polynomial for y
for example:
4301/1073+246/1073*t , -1341/2684+2842/5368*t
The polynomials can have higher degree and you can replace t by any single letter as long as your are consistent within the polynomial. See test/Kinetic_data_structures/data/Delaunay_triangulation_2.input for an example.
----- Original Message ----
To:
Sent: Thursday, February 7, 2008 8:19:31 PM
On Feb 7, 2008, at 12:07 AM, Mahmood Naderan wrote:
Hello,Assuming you are talking about Delaunay_triangulation_2 it uses boost
I cannot understand which file is used by "Kinetic_data_structures"
demo neither in CGAL 3.2 nor CGAL 3.3.1
std::string file;
return run<CGAL::Kinetic::Exact_simulation_traits>(argc, argv,
n,d,seed, file);
if (file.empty())
So which file? How can I change the input file?
program options to handle the command line arguments. So "./
Delaunay_triangulation_2 --help" tells you the command line argument
usage. The file name is just one of the arguments.
Also what changes appeared for this section in 3.3.1 in compared toNo important changes were made to the demos.
3.2? It there any changelog?
and another question is about manual. I did not find any guide inThe documentation of the display code could use some improvement, yes.
cgal manual about the demo and related QT functions. Is it "Kinetic
framework" section?
There are very minimal pages for the individual classes (look for
Kinetic::Qt... in the index). The code and interfaces are pretty
simple, so just looking at Delaunay_triangulation_2.cpp and the
Kinetic/IO/Qt*2.h files should give you a good idea. They don't have
many capabilities beyond what the demo does.
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.
http://tools.search.yahoo.com/newsearch/category.php?category=shopping
- Re: [cgal-discuss] Kinetic_data_structures... some questions, Mahmood Naderan, 02/08/2008
- Re: [cgal-discuss] Kinetic_data_structures... some questions, Daniel Russel, 02/08/2008
- <Possible follow-up(s)>
- [cgal-discuss][Polyhedron] Integrate several Off models into one single model, Max, 02/08/2008
- Re: [cgal-discuss] Kinetic_data_structures... some questions, Mahmood Naderan, 02/09/2008
