- To:
- Subject: Re: [cgal-discuss] Kinetic_data_structures... some questions
- Date: Fri, 8 Feb 2008 09:20:19 -0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:from:to:in-reply-to:content-type:content-transfer-encoding:mime-version:subject:date:references:x-mailer; b=trQCycpGRZIhnfGCXlsjv6NuBkoNVp40nu53hGCFNh2w5O3CNa2iOlw0uPlTvDZjlCGEuxCY4/ii2YVo7fUy9JBajP+GO7ABj9QQy7DXcy08XUcjkbFsxHAqrbp5ZIy59w7koQw03vXa+RuMHjIvj1ongjWfWnDEJBxuPO0WjU8=
Those are just stationary points. They will work, but not be terribly interesting to watch :-) They are more interesting as inputs to the update_Delauany_trianglation_2.
On Feb 8, 2008, at 4:09 AM, Mahmood Naderan wrote:
Thank you,
How about "afterNNN" and "beforeNNN" formats in "CGAL-3.3.1\demo \Kinetic_data_structures\data"? For example, "after002":
0 0
261.556 368.49
355.421 321.043
258.829 257.795
296.059 374.507
335.804 340.896
276.11 389.494
317.786 278.038
298.064 258.447
245.414 349.746
336.665 298.648
600 600
225.064 293.26
316.217 358.874
276.658 239.092
0 600
225.965 333.489
208.967 313.376
242.246 275.883
600 0
Mahmood Naderan
http://ce.sharif.edu/~m_naderan
----- Original Message ----
To:
Sent: Friday, February 8, 2008 11:17:06 AM
Thanks for reply. But "CGAL_USE_BOOST_PROGRAM_OPTIONS" preprocessorIn that case set the "file" string variable at the start of main to
is not defined. During debugging, the program skips that section.
the name of the file. If that variable is empty it just generates some
points randomly. The file format is quite simple: a series of lines like
polynomial for x, polynomial for y
for example:
4301/1073+246/1073*t , -1341/2684+2842/5368*t
The polynomials can have higher degree and you can replace t by any
single letter as long as your are consistent within the polynomial.
See test/Kinetic_data_structures/data/Delaunay_triangulation_2.input
for an example.
To:
Sent: Thursday, February 7, 2008 8:19:31 PM
On Feb 7, 2008, at 12:07 AM, Mahmood Naderan wrote:
Hello,Assuming you are talking about Delaunay_triangulation_2 it uses boost
I cannot understand which file is used by "Kinetic_data_structures"
demo neither in CGAL 3.2 nor CGAL 3.3.1
std::string file;
return run<CGAL::Kinetic::Exact_simulation_traits>(argc, argv,
n,d,seed, file);
if (file.empty())
So which file? How can I change the input file?
program options to handle the command line arguments. So "./
Delaunay_triangulation_2 --help" tells you the command line argument
usage. The file name is just one of the arguments.
Also what changes appeared for this section in 3.3.1 in compared toNo important changes were made to the demos.
3.2? It there any changelog?
and another question is about manual. I did not find any guide inThe documentation of the display code could use some improvement, yes.
cgal manual about the demo and related QT functions. Is it "Kinetic
framework" section?
There are very minimal pages for the individual classes (look for
Kinetic::Qt... in the index). The code and interfaces are pretty
simple, so just looking at Delaunay_triangulation_2.cpp and the
Kinetic/IO/Qt*2.h files should give you a good idea. They don't have
many capabilities beyond what the demo does.
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.
http://tools.search.yahoo.com/newsearch/category.php?category=shopping
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
- Re: [cgal-discuss] Kinetic_data_structures... some questions, Mahmood Naderan, 02/08/2008
- Re: [cgal-discuss] Kinetic_data_structures... some questions, Daniel Russel, 02/08/2008
- <Possible follow-up(s)>
- [cgal-discuss][Polyhedron] Integrate several Off models into one single model, Max, 02/08/2008
- Re: [cgal-discuss] Kinetic_data_structures... some questions, Mahmood Naderan, 02/09/2008
