cgal-discuss - Re: [cgal-discuss][Polyhedron] Integrate several Off models into one single model
  • To: "" <>
  • Subject: Re: [cgal-discuss][Polyhedron] Integrate several Off models into one single model
  • Date: Sat, 9 Feb 2008 23:45:51 +0800
  • Disposition-notification-to: "Max" <>
  • Organization: LoadCom
I happened to find the Nef_polyhedron_3::Build_polyhedron<HDS> template class,
it's quite similar to my code, except that it uses the visitor pattern.
I guess there is an exsting class or function that can meet my need.
Max
>Hi all,
>I want to integrate several Off models(manifold) into a single model.
>I found the incremental builder example for polyhedron in the documentation.
>I adapted the code for my purpose. Everything seems to be smooth. The
>program
>ends successfully, and the visulization of the result is just want I
>expected.
>However, having a closer look at the resulting file, I find a strange
>phenomenom - the resulting number of vertices and facets is much greater
>than what they 'should me'.
>For example, I was combining 6 similar but disconnected models, each has 578
>vertices and 1152 facets. To my surprise, the resulting model has 12138
>vertices
>and 24192 facets, far more than 6*578 and 6*1152, respectively.
>All of the working code is as follows:
>// A modifier creating a polyhedron with the incremental builder
>template <class Polyhedron_3>
>class Build_polyhedron : public CGAL::Modifier_base<typename
>Polyhedron_3::HDS>
> typedef typename Polyhedron_3::HDS HDS;
> typedef typename Polyhedron_3::Point_const_iterator Point_iterator;
> typedef typename Polyhedron_3::Facet_const_iterator Facet_iterator;
> typedef typename Polyhedron_3::Halfedge_around_facet_const_circulator
> Halfedge_facet_circulator;
> const Polyhedron_3 &p_;
> Build_polyhedron() {} // not open to user
>public:
> explicit Build_polyhedron(const Polyhedron_3 &p) : p_(p) {}
> void operator() (HDS& hds)
> typedef CGAL::Polyhedron_incremental_builder_3<HDS> Builder;
> // Postcondition: `hds' is a valid polyhedral surface.
> Builder B(hds, true);
> // building a surface
> B.begin_surface(p_.size_of_vertices(), 1);
> // building vertices
> for(Point_iterator p = p_.points_begin(); p !=
> p_.points_end(); ++p)
> B.add_vertex(*p);
> // building facets
> for(Facet_iterator f = p_.facets_begin(); f !=
> p_.facets_end(); ++f)
> B.begin_facet();
> Halfedge_facet_circulator c = f->facet_begin();
> // Facets in polyhedral surfaces are at least
> triangles.
> CGAL_assertion(CGAL::circulator_size(c) >= 3);
> do {
> B.add_vertex_to_facet(std::distance(p_.vertices_begin(), c->vertex()));
> } while ( ++c != f->facet_begin());
> B.end_facet();
> B.end_surface();
>// Integrate source into target
>template<class Polyhedron_3>
>void IntegratePolyhedron(Polyhedron_3 &target, const Polyhedron_3 &source)
> Build_polyhedron<Polyhedron_3> polyhedron(source);
> target.delegate(polyhedron);
>Thanks in advance for any help.
>B/Rgds
>Max
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
