- To: "" <>
- Subject: RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel
- Date: Fri, 22 Feb 2008 13:15:01 -0800
- Accept-language: en-US, en-CA
- Acceptlanguage: en-US, en-CA
Hi Peter,
The description in the File I/O section of the User Manual is excellent, and
I should have read it carefully before. It restates what you have in this
thread. I agree with you when you mention that that section in the manual
can be overlooked. Perhaps a separate heading with "Kernel Selection" can
provide more insight to the user.
Yes, I have used NDEBUG and O2.
Stephen
-----Original Message-----
[mailto:]
Sent: February-22-08 11:39 AM
To:
Hi Stephen,
I introduced these new items, because it was clear that filtered kernels
are inefficient with the old ones. The new ones allow efficient
filtering. Since I mostly wanted to speed up Cartesian kernels and
therefore allow handling of double coordinates, I write about it at a
seemingly strange place of the documentation. It's in the user manual
under File I/O.
BTW, do you compile with -DNDEBUG and -O2? That usually gives a big
efficiency boost.
Peter
On Fri, 2008-02-22 at 11:19 -0800, Stephen Wong wrote:
> Hi Peter,
> I didn't use SNC_indexed_items before. I am noticing about 30-40%
> improvement in computation time (30% faster) after using
> Exact_constructions_exact_predicates and SNC_indexed_items!
> What does the indexed items do? It's not mentioned in the documentation -
> in fact, the current documentation suggests that you should stay with the
> default, SNC_items.
> Thanks for your excellent analysis.
> Stephen
> From: Peter Hachenberger
> [mailto:]
> Sent: February-22-08 4:14 AM
> To:
> Subject: Re: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel
> Hi Stephen,
> I performed some tests. Assuming you have gmp but no leda, the
> Exact_predicate_exact_constructions_kernel is up to double as fast as
> all the others. Don't forget to use the SNC_indexed_items with that
> kernel. Also all the other kernels (besides the extended kernels) profit
> from the SNC_indexed_items. The second fastest seems to be
> Simple_cartesian<Gmpq>. The homogeneous kernels were in general slower
> than the Cartesians. That would be different with LEDA.
> Homogeneous<leda_integer> is very fast.
> Peter
> On Mon, 2008-02-18 at 11:38 -0800, Stephen Wong wrote:
> > Hi there,
> > I am wondering what is the most computationally-efficient kernel that
> > is allowable in Nef Polyhedra in 3D (Boolean operations), in the set
> > of rational numbers Q. Right now I am using Cartesian<Gmpq>, a
> > variant of Exact_predicate_exact_constructions_kernel. I am wondering
> > if there is a Kernel (than I have stated) that performs more
> > efficiently. If not, is there a more efficient number type than Gmpq
> > that is compatible with 3D Nef Polyhedra?
> > On the same topic of discussion, if I were to use kernels representing
> > Z, which is the most efficient kernel?
> > Thanks,
> > Stephen
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [3d_boolean_ops] Most Efficient Rational Kernel, Stephen Wong, 02/18/2008
- Re: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Max, 02/19/2008
- Re: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Peter Hachenberger, 02/22/2008
- RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Stephen Wong, 02/22/2008
- RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Peter Hachenberger, 02/22/2008
- RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Maarten Moesen, 02/25/2008
- RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Max, 02/23/2008
